Here's a nagging issue I've been having.
When I first start up the truck and put it in drive there is usually a two or three second lag before it engages. When it does engage it catches on slow and gentle as opposed to harshly. There is no lag in Reverse, it immediately picks up reverse almost harshly (briskly you could say, not hard enough to worry about mounts but you know it happened).
So any ideas? Other than this the transmission works just peachy, and yes, the fluid is full. It's been doing this since I changed out the front pump seal, before then it got a bit of abuse with low fluid (but not a whole lot).
Any ideas? Ultimately I plan to tow with this truck so obviously the transmission is important to me (and yes, before it tows it's first load it will have an aftermarket cooler with a thermostat and gauge).
C6 - Delayed forward engagement when cold
- GSequoia
www.advlifestyle.com
1971 Camper Special (390 / C6 / D60)
1970 F250 High Boy (NP435 / Dana 24 / No engine, rusted to hell and back body, project to combine with above.)
1966 Rustang (289 / C4 Project stalled for ages)
1989 Jeep Cherokee (4.0 / Auto / D30 / D44 / 35's)
1996 Jeep Cherokee (4.0 / Auto / D30 / D35)
- Mancar1
Re: C6 - Delayed forward engagement when cold
Maybe the Vauccum Modulator is causing the problem. I had a simaler problem on a C-6 years back. A new Modulator fixed it. I think maybe you can adjust it. I am not a tranny expert, just throwing that out there.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- BobbyFord
How many miles on the trans?
- GSequoia
A lotBobbyFord wrote:How many miles on the trans?
Probably 175,000. +/- It's the original transmission for the truck.
- BobbyFord
Time for a rebuild.
- 70_F100
Forward clutch seal is getting hard and by-passing when cold.
Once it warms up, the seal expands enough to work properly.
Famous on a C6.
Famous on a C6.
- GSequoia
Nooooooo!BobbyFord wrote:Time for a rebuild.
I know it'll need it soon, I'd do it now but I don't know what I want to do transmission wise with this truck. I'd like overdrive eventually but haven't yet decided whether I want to do that with an automatic or manual.
- Mancar1
Got my fingers crossed for you. Could keep going for a lotta miles. Or it could, you know.GSequoia wrote:Nooooooo!BobbyFord wrote:Time for a rebuild.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- GSequoia
Yup... Sorta like my Vic, didn't last a thousand miles before the transmission started to eat itself That's first in line for a rebuild. Then I have a Jeep transmission (AW4) to rebuild at some point (low priority), then today my wife's Mini decided to slip really bad on me, I fear that transmission might be eating itself with only 78,000 miles on it. Sigh... See why I want to go to a good old manual!Mancar1 wrote:Got my fingers crossed for you. Could keep going for a lotta miles. Or it could, you know.GSequoia wrote:Nooooooo!BobbyFord wrote:Time for a rebuild.
