429 engine swap
corntown67
429 engine swap
Post by corntown67 »
well I have a 1970 ford truck it has a 302 3 speed on the floor,I also have a 429 engine out of a early 70s mercury montego I am wanting to make the truck into a big block hotrod, I want to put an automatic in it, I know where theres a 1974 lincoln with a 460 it has a c6 automatic I was wanting some help with what all im gonna have to do to make this swap work, I am wanting to bolt the 429 up to the c6 and drop it into my truck, I think Ill need different engine perches and an auto crossmember Ive done some research on these parts but the places that Ive found theses things for sale says not for licoln or merury applications, I would appreciate any help with this conversion, thank you
BobbyFord
Re: 429 engine swap
Post by BobbyFord »
Welcome to the website.
You will need engine perches and mounts (3 pieces per side) from a 73-79 F Series truck w/460. You will also need an automatic crossmember.
The "not for Lincoln or Mercury" refers to the MEL series engine not the 385 series.
corntown67
Re: 429 engine swap
Hey thanks for the welcome appreciate that, so basically what your saying is that the not for lincoln or mercury doesnt apply to me because I have a 385 series engine,is that because of the age, I dont know the difference,I have never heard of mel or 385 series,thanks for the reply.
BobbyFord
Re: 429 engine swap
Post by BobbyFord »
corntown67 wrote:Hey thanks for the welcome appreciate that, so basically what your saying is that the not for lincoln or mercury doesnt apply to me because I have a 385 series engine,is that because of the age, I dont know the difference,I have never heard of mel or 385 series,thanks for the reply.
It's because the 385 and the MEL are two different animals. MEL = Mercury Edsel Lincoln.
corntown67
Re: 429 engine swap
Hey thanks for the info,gonna get the parts soon and get started with the swap,gonna make a winter project out of it.
Re: 429 engine swap
you may find that the car c6 will require the trans mount and crossmember to be modified in some way. here are some 460 engine mounts for a truck. http://www.fordification.com/forum/view ... 5C#p496433
Bigblock514
Re: 429 engine swap
Post by Bigblock514 »
A place call L&L products produces the engine mounts that you'll need to make this swap without changing the perches,you can use
standard fe perches for the 385 engine. They'll only set you back a cool 125.00 bucks a lite mod to your trans crossmember and its a rap!
Big Block Fords Rock!
Hawkrod
Re: 429 engine swap
Post by Hawkrod »
Bigblock514 wrote:A place call L&L products produces the engine mounts that you'll need to make this swap without changing the perches,you can use
Yeah that would work but why do it the hokey way when it is about the same price to do it right? Using the Ford original brackets allows all stock parts to fit as is. L&L is fine but I had to have new exhaust head pipes made as it was just enough different. I didn't buy the L&L stuff but it came with teh truck. Ever since then I use original Ford stuff as long as it is not a 4X4. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
Bigblock514
Re: 429 engine swap
I'm glad you told me this because my motors almost finish and I don't need any hick ups! Thanks!
I already think I've got to sell the farm to build this truck the way I want it.
corntown67
Re: 429 engine swap
yea thanks for the info,I'll check on the L&L stuff but I'm gonna check and see about getting original,thanks alot,I'll post some pics sometime.
