Newbie to the bumps
Loyro
Newbie to the bumps
Post by Loyro »
I have had several dent sides over the years but I am the proud new owner of a 68 F350 with a 300 I6 stake side. The truck has been sitting dead in a field for 8+ years. I have resurrected the 300 by rebuilding the carb and moving the distributer 180 degrees (someone must have been struggling to diagnose a problem) but I now find that the transmission does nothing in any gear. This truck has me excited to bring it back to life but not sure about the tranny. Think it is a cruise o matic (PFB D3). looks like it will probably need a rebuild. Is it worth it or should I look for a different tranny. What wil fit behind a 300?
THE WORD-FAST FORDS-BAD HARLEYS & My HOT WIFE....THE MAN IS FED
1970FordTK
Re: Newbie to the bumps
Post by 1970FordTK »
Welcome from North Carolina, I'm sure some of the smart folks will be along soon and help you out on that. :thup:
Mancar1
Post by Mancar1 »
Hello from Tehama County Calif.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
Loyro
Post by Loyro »
Thanks for the"welcomes", I am excited that I found this site. What a wealth of information and everyone seems to be a good caring and sharing group of people.
guerra
Post by guerra »
:wel: from west Texas
1967 f-100 lwb 360/c6
1969 f-100 swb 351/c6 (project)
fireguywtc
Post by fireguywtc »
:wel: from Texas! :fr:
Bill
impappy
Post by impappy »
Welcome from Sacramento, Ca. I have a similar story with a 68 f250. the automatic transmission in my truck wouldnt do anything when I first got the engine to run. (it also sat in a field for 10+ years) I discovered that the front seal of the tranny had failed and there was no ATF left. Five quarts of ATF later and it was shifting well enough to drive it out of the field and make it the 30 miles to home.
If the definition of crazy is "doing the same thing over and over again and expecting a different result " It would certainly explain why I keep buying these old Fords
Loyro
Post by Loyro »
I did check the fluid and it is full and has good color. I also checked the linkage and it is all connected. Running through all the gears, there is nothing not even any sound from the pump. I would think it would whine or something.
bigmerc2003
Post by bigmerc2003 »
Did you check to make sure the trans is bolted to the flex plate? Or they could have had a trans problem and changed the fluid?? Just a few thoughts sounds like a fun project
forrestbump
Post by forrestbump »
:wel: from Lake Elsinore SoCal :fr:
Larry
Venado82
Post by Venado82 »
:wel: from the Panhandle of Texas
Half of something is better than ALL of nothing!
http://www.facebook.com/anthony.inman#! ... 1184119868
randyvines
Post by randyvines »
welcome, you probably can get more responses on the transmission section. More people looking there. Any way good luck and enjoy your bump. :wel:
Loyro
Post by Loyro »
I have now posted over in the drive train forum. Thanks for the greetings! glad to join you all
FLATBEDFORD
Post by FLATBEDFORD »
Welcome fellow F350 owner, from NY.
My Photo Gallery
foghorn
Post by foghorn »
:wel: from Okla Also rember two thing #1 :fr: #2 :nopix:
Foggy 8)
Work is for people that dont know how to fish
