1968 F750 TRACTOR
Re: 1968 F750 TRACTOR
i think it's in the suspension because there was an f750 bus parked next to the f600 i got the fenders from and they sat the same.
1967 f100 stepside 300ci I6
1972 longbed trailer
- bryantracing460
I've got a 59 F-600, and was thinking about putting a late model dually bed on it. Saw a pic of a peterbilt done that way one time, with the aluminum fuel tanks on the side, looked real cool.
Jeremy
Drive It Like You Stole It.........NO FEAR!
69 F-100 swb 2wd 460 C-6. 86 F-150 super cab 2wd 302 AOD.85 Bronco 4wd 300 AOD.
http://www.myspace.com/bryantracing460
- dolinick
I had a though from a guy here who is putting f600 front fenders on his f100 stepside. he is cutting the bed down the centerline i think and widening it to match the wider f600 fenders. maybe something similar could be done to fabricate a dually type bed that matches the styling of the 67-72 model trucks.
I plan on removing the dual tanks on my F750 as well or at least removing one and relocating the other. I'd certainly be willing to part with them for a 20 gallon or somewhat larger replacement fuel tank or fuel cell.
Dan
Dan
2003 7.3L F250
1968 F500 Utility Truck
that would be beastly. go for it!
- FormerMarine1981
Just my I would Keep the front fenders and modify a bed to put on it. Maybe find some more front fenders like the ones you have and make some dually wheel wells out of them. Should be fairly easy to cut the wheel well out of a bed and graft a patch panel to smooth out where it was. The modified fenders for wheel wells would make it easier to hide mods to the actual bed for your tire clearance. Not sure if it makes sense written out but It looks good in my head
- FLATBEDFORD
I say put a flatbed on it.
My Photo Gallery
My Photo Gallery
- rjewkes
If theres room maybe even a second set of dualies of course you'd need a front set that has a driveline pass through so both could be hooked up. then it could have a 4x4 rear setup like the newer ones.
fuelly.com
fuelly.com
- bryantracing460
Or maybe find a flareside bed and use the fenders off it.FormerMarine1981 wrote:Just my I would Keep the front fenders and modify a bed to put on it. Maybe find some more front fenders like the ones you have and make some dually wheel wells out of them. Should be fairly easy to cut the wheel well out of a bed and graft a patch panel to smooth out where it was. The modified fenders for wheel wells would make it easier to hide mods to the actual bed for your tire clearance. Not sure if it makes sense written out but It looks good in my head
Jeremy
- FormerMarine1981
A Flareside bed would be easier to make. Could possibly make a flat bed that you can fasten the bed sides to and take off easily for when you needed to....
- rjewkes
Could even leave in the fifth wheel or even adapt it to one of the removeable fifth wheels. so it would be ready for any project in a moments notice.
Heck if i had one and i could get it repaired to above current standards i'd run it OTR. After a Deisel swap up. Something Cummins or detroit or even IDI.
fuelly.com
fuelly.com
- dolinick
Well, it's just a novelty for me. I don't have any practical uses for it yet. I don't even know if I could make any money with it to justify keeping it. Just a toy. It is true I can haul tons of water but I don't have any major plans at the moment. What about a flatbed wrecker to haul scrap metal and sometimes cars. Actually I really like it. Just hearing it crank and come to life every time is still a thrill. Also the sound of the air compressor and air brakes reminds me of my trucking days.
Instead of getting my long bed running I bought a little red '67 stepside. It will be my everyday running around vehicle I suppose.
Dan
Dan
2003 7.3L F250
i see someone is copying me... although your 67 look a hell of alot better than mine does. nice find!dolinick wrote:
Dan
- dolinick
I know this thread is old but I've been thinking about driving my F750 lately. Assume I manage to get her registered and insured. I thought I'd keep her around and drive her around here in town. I don't drive very far mostly. I'd criuse maybe on friday nights a little bit and maybe get groceries and pick up the kids from school and stuff like that.
I don't know how far the tires will go that are currently on it. But then again I ought to just take things one at a time.
1. transfer the title into my name. (still got the government form for that)
2. get insurance
3. replace the air compressor belt. (fix low air pressure warning that I disabled because it kept going off)
4. start driving the truck around (woohoo!)
5. find out where all the oil leaks from.
2. get insurance
2003 7.3L F250
- Ranchero50
The tires last just about forever. if you plan on driving it I'd seriously consider taking a couple leafs out of the spring packs.
These things are pretty hard on fuel
Jamie
Jamie
- 1982 flareside
i would get rid them old split rims
Jeremy
1971 Ford F250 camper special 360 T18(old model) 4 speed 4.11 gears 2wd with 1969 doghouse soon to be daily driver FRANKENFORD
1982 Ford F150 flareside 300 T18(new model) 4 speed 4.11 gears 4wd Daily driver
Some people say my truck is ugly and all i say is "Beauty is in the eyes of the beholder.
