B&M c6 tranny pan
B&M c6 tranny pan
would i fit without messing with the frame support
- ForingaMex
Re: B&M c6 tranny pan
I'm not sure but isn't the crossmember in front of the pan? Just thinkin...
-Jake
"Better to remain silent and be thought a fool than to speak out and remove all doubt." -Abraham Lincoln
-02 Dodge Ram Quad Cab
-72 Ford F100 LWB 390/C6 (Retired for now till I can rebuild/transform it)
-2000 Ford Windstar (Family Vehicle)
-92 VW Beetle (Mexican)
my worry is the cross member between the strut rod bushings
- basketcase0302
I've got plenty of room under my little 302 with the C-6 for a deeper pan, (it's on my "wish list" someday).
What engine you have in the truck? F-100/250/350?
F100 390fe c6 shorty
I have one on a dent side parts truck but the cross member looks different dont know if it was cut
- basketcase0302
This probably won't help you then? Hopefully someone else here, (Bobby maybe) can pipe in that has a BBF or an FE/C-6 combo.flakos 69 on Fri Aug 27, 2010 11:39 am
Here's the best picture i have of my little 302 with the C-6, but it doesn't really show the crossmember at all...
Up until recently I had my '68 bump with a C6 with a B&M Deep pan on it. I think i had to file the leading edge of the fins down to a 45 for a little bit of clearance, but i'm not positive. It might have been the AOD before it that i had to do that to. I'll go look at the pan this afternoon to be for sure, but either way it was on there without any real issue with the front crossmember.
I just looked at mine and its a TCI cast aluminum deep pans, but I didn't have to modify it.
seems that the crossmember is different on the dent side I will get pictures tomorrow
I started to remove the 69's hopefully they interchange
the narrow cross member is the one off the 76 the wide one is off the 69
the eariler cross member like the one i have is pretty close to my deep c-6 tci pan 1/4 in but it clears but is a 65 w/ 429 c-6 but ford didnt like to change things a whole lot. wes
69 bronco 4x4 - 70 bronco tube chassies 4x4 351-w c-6 - 65 f-100 w/69 429- c-6 - 03 ranger 4x4 - 99 f-350 4x4 diesel
