I put a new battery, starter, alt, reg, battery and starter cable, solenoid, starter swicth in the last 2 months. I had an electrical short and got that fixed. I adjusted points, and started the engine and set the idle and set the dimming. I turned the fuel mixture screws all the way in and back out 1 1/2 turns and then an additional 1/2 turn. Was running pretty then. After 10 minutes, I shut it off and tried to restart. The battery was so low it only turned very slowly and stopped. I took the neg cable off and got a test light to see if there was another short in the wiring and the light did not come on. I hooked the battery up to a charger and it registered as needing charged. The needle was on the 15 amp mark on the charger. Any suggestions?
Thanks, Robert
