Hi,
I just bought a 1967 F350 with a custom built Dreamer camper on it.
I'm sure this is a topic that has been hashed on here many times, but I have been searching old post and I cann't seem to find what I'am looking for.
My door tag has a "G" for the trans code, which according to the vin decoder, is a cruise-o-matic.
I am not a fan of auto trannnys and would like to put a manual in it. Can I get some input as far as the best way to do it or should I bother with it.
Thanks
Gary
1967 F350 Tranny swap
Re: 1967 F350 Tranny swap
you will need the manual transmission flywheel clutch pressure plate throw out bearing bellhousing clutch fork manual transmission floor cover for floor shift correct length driveshaft. manual trans starter and engine plate. clutch pedal setup.
- 70_F100
If it's got an FE (probably 352), the starter and engine plate are the same for manual and automatic.
Don't forget the manual transmission crossmember and rear tranny mount.
Does everything have to be from a 67-72 or could I use a 73-79 donar truck?
