HRDROKN
Re: 1969 Ford Crew Cab / Cummins Project
Post by HRDROKN »
bb429power wrote:Lets hope she turns out like this..........
http://www.youtube.com/watch?v=hkwdA-MT ... uH1aaugoH0
Good work!
Nice!
If that is the truck I'm thinking of.... it is one heck of a clean crew cab. I think the owner hangs out on powerstroke nation. So I guess next time someone asks what the heck I'm going to do with this truck, I will just point them to that video! LOL
:D
RTG_RACING
Post by RTG_RACING »
!$%& me man this is outstanding.
HRDROKN
Post by HRDROKN »
OK.... took a little break from the project, been doing some dirtbiking...
I got the new coils in... I had miss calculated just how heavy this truck was going to be! So now I have 275's over 450's rather than the old set up which was 500's over 750"s!
:wink:
HRDROKN
Post by HRDROKN »
Installed my injection pump and found the pump shaft hits the timming gear access cover...... so looks like I welded the backing ring on the wrong side!
HRDROKN
Post by HRDROKN »
Resolved my goof-up with the timing cover.... bored a hole for the pump shaft/nut to clear and then welded an outer piece to close her back up.
:wink:
HRDROKN
Post by HRDROKN »
Figured out what to do with this oil drain line for the low pressure turbo...
I had such a tight bend that the hose just wanted to kink...
So my brother from another mother gave me an idea...
Works great!
HRDROKN
Post by HRDROKN »
So my timing cover issue is resolved.... I needed to install a woodruff key in my adjustable pump gear and got that done. So I had to re-set the pump timing and while I was baring the motor over I heard a loud snap! That can't be good.... apparently one of the pushrod cups got miss aligned with the adjusting ball (all my rockers still loose is why) an popped the rod to the outside of the adjusting ball effectively bending a new Hamilton push rod! :doh:
It also scored the adjusting ball..... any of you diesel guys have an extra laying around for a 12 valve?
:hmm:
averagef250
Post by averagef250 »
You want slotted or hex?
HRDROKN
Post by HRDROKN »
averagef250 wrote:You want slotted or hex?
Slotted if you have one.... I can send you some $$$ for shipping?
Mark
HRDROKN
Post by HRDROKN »
Any thoughts as to which style alternator to use? The advantages of the Denso unit on the left is that it is a good bit smaller in size and still does 120 amps (I believe)... the Delco unit could be a 160 amp version.
sport71
Post by sport71 »
I thought my truck bad a$$. You have a great truck even though you havnt finished it. its on its way to be the only one like that on earth... :D :thup:
Those who do not learn the lessons of history, are doomed to repeat it.
HRDROKN
Post by HRDROKN »
I went with a Denso 180 amp alternator, size was the biggest consideration as you can see things are getting a bit crowded!
:wink:
HRDROKN
Post by HRDROKN »
Got the radiator mounted up to the core support...
:wink:
BiggDogg
Post by BiggDogg »
Oh man, this is liking waiting for Christmas to come when your a little kid! Very exciting :pop:
1970 F250 Camper Special
jnash40
Post by jnash40 »
i agree def one of the coolest conversions ever
