Timmytim's 1970 f100
- timmytim
Here is my Truck. I plan to chronicalize my experiences working on it. It looks great at 10 foot but a closer look and you will see alot of work. It has a 240 inline 6 with a auto and 370 gears. Standard brakes and manual steering. The man before me took out the 3 on the tree and put in a modified auto trans for towing.With only 37k miles plus it has little more than a heater and seat. Over time this will change
buy'em dirty sale'em clean
get more money for the same
machine.....
My 1967 bump: http://www.fordification.com/forum/view ... 09#p668209
My 1970 Bump: http://www.fordification.com/forum/view ... 16&t=50726
- timmytim
Re: Timmytim's 1970 f100
I have already replaced the points with a pertronix ignitor,new plugs,wire,cap,rotor button, and coil. Replaced the flasher. Replaced the nss. Added 40 series flowmaster with duel tail pipes. Tinted the windows. Added alarm system. And added a tach...
machine.....
- timmytim
Next on my to do list is power steering. I have already bout all of the parts mostly used. I degreased the parts and painted flat black. While I have the pulleys off I will replace the water pump with a new one(see new blue waterpump in pic). The one on the truck is making a bearing noise.
machine.....
- timmytim
machine.....
Really nice truck
. Someday I want get one like that and put a fox body engine/trans in it.
60 Mercury Comet
65 Ford Econoline
77 Ford F250 "lowboy" 4x4
09 Harley Xl1200c
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
- timmytim
thanks fordtruck..i have a built 302 in basement but im having so much fun with this inline...it can pull a moble home off its blocks!!
machine.....
I know what you mean I just had a 70 F100 that had a 302/NP435 and I traded it for a 69 F250 highboy with a 300/NP435 and the 300 has more pulling power than that 302 did...but the 4wd probably helps toootimmytim wrote:thanks fordtruck..i have a built 302 in basement but im having so much fun with this inline...it can pull a moble home off its blocks!!
Is your inline all stock?
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
- papabug71
Just to verify, you do have a P/S column also right? You will need one for the P/S swap.
Looks like a slick old ford to me. I bet it pulls like a ox with the 3:70's in the rear.
Matt
Mine since 5/7/'94
302 / 3 speed / 3:25's
- timmytim
fordtruck, yea its all stock all the way down to the one barrel!!! It redlines at about 3800rpm...it sounds real good with that 40 flowmaster...at idle you would swear it was a 5.0FordTruck wrote:I know what you mean I just had a 70 F100 that had a 302/NP435 and I traded it for a 69 F250 highboy with a 300/NP435 and the 300 has more pulling power than that 302 did...but the 4wd probably helps toootimmytim wrote:thanks fordtruck..i have a built 302 in basement but im having so much fun with this inline...it can pull a moble home off its blocks!!. Myself I've awlyes kinda had a thing for the old inlines espically for towing or pulling something
machine.....
- timmytim
thanks papabug71, yea ive already determined it is a ps column after chatting with folks on here and seeing pictures.papabug71 wrote:Just to verify, you do have a P/S column also right? You will need one for the P/S swap.
machine.....
Nice ride, yer cruising right along with upgrades! Looking good
1970 F250 Camper Special
- timmytim
machine.....
- papabug71
Good deal
From the pics you posted, it looks like a super clean old truck
Matt
Mine since 5/7/'94
- kyle ray
looks good to me!!!
- 69FLATBED
Sweet looking ride Tim!
Troy
_________________________
2000 F350 4x4 Crew Cab PSD
1969 F350 Flatbed 360 4spd DRW
!968 F250 4x4 Crew Cab SWB
Love my diesels hope to be gasoline free soon!
