Chronicles of the Blue Goose!
Re: The Blue Goose!
Looking good, I hope you find a carb.
Justin
1986 f150 5.0 (my DD)
- Orange Beezy
Re: The Blue Goose!
Looks good. The hose that tore off is a breather hose for the rear end,so if you go thru deep water the water doesnt get in the rear end itself.
SoCalExile wrote:Finally got the wheels on! Also changed the shocks, which dropped the truck down about 2-3"!
Before:
[ Image ]
After:
[ Image ]
[ Image ]
The old shocks:
[ Image ]
While changing the shocks I accidentally tore off a dry-rotted hose that was running from a connection point that my brake lines shared:
[ Image ]
It was just a empty hose running up through the frame rails towards the back of the truck. Wasn't connected to anything. What is it for?
I also rebuilt the carb today. Now the damn thing won't start again. it looks pretty rough, so I may see if I can score a better one at the Charlotte Auto Fair next weekend.
Next on the agenda is the transmission. I think it bled out a couple quarts while I was in Haiti. I'll probably drop it out and take it to a shop though.
I WILL KEEP MY GUNS<MY FREEDOM AND MY MONEY!
YOU CAN KEEP THE "CHANGE"!
1968 FORD F250 CC LWB 390 C6 w/1972 front disc brakes
1965 Ford Fastback 2+2 (SOLD)
- SoCalExile
Re: The Blue Goose!
is it something best plugged shut or is it better to find a replacement hose?Orange Beezy wrote:Looks good. The hose that tore off is a breather hose for the rear end,so if you go thru deep water the water doesnt get in the rear end itself.
- knightfire83
Re: The Blue Goose!
Ya don't want to plug it... Pressure builds as the rear end parts heat up from use and expands. If it's plugged the only way to relieve the pressure is leaking oil thru the seals.
I removed the vent from the axle housing and cleaned it out with a drill bit, it was packed with dirt and grime (it just screws in.) Then replaced the hose with a section of fuel line and a clamp, ran it up to the top of the frame.
1970 Ford F250 4x4 ~ Sold.
- SoCalExile
Re: The Blue Goose!
Yanked off the timing chain today. A few pics and notes:
- the water pump is rusty and filthy. What you see is what it was like when I yanked it off. the motor has been running pretty damn hot, so I plan to replace the water pump and thermostat, and while I'm at it the fuel pump.
- the timing chain was pretty loose, as you can see. The chain fell off the gears before I even got them off.
- there's some burnt-smelling sludge on the side of the motor. I'm thinking it may be a good idea to drop the oil pan and clean it out along with the oil pump screen (may be a cause of my low oil pressure?)
Pics:
Pics:
- SoCalExile
Re: Chronicles of the Blue Goose!
It's been awhile since I updated this. Here's the list of what's been done:
New comp timing chain that compensates for the 4* advance in the factory cam.
New water pump
New oil pump
New thermostat
New fuel pump and line
New radiator and hoses
Flex Fan
Accel Super Stock Coil + wires.
Carb rebuild
F600 dash panel
New radio from http://www.VintageVibes.net (great guys)
New heater controls
New glove box
3-Point seat belts
Oh yeah..NEW PIPES & HEADERS!
Pics:
She's all ready for her trip to Texas tomorrow.
New water pump
New oil pump
New thermostat
Flex Fan
Carb rebuild
F600 dash panel
New heater controls
New glove box
3-Point seat belts
Pics:
- stephen44
looking good - what PIPES & HEADERS! did you put on - what does it sound like?
Stephen
Stephen
thanks
Stephen
(1967 F100, FE352, 2wd, 3 on the tree, flareside)
Stephen
- SoCalExile
Hooker headers with glasspacks and 2 1/2" pipes. The sound isn't as deep as some trucks...a more old school throaty sound.stephen44 wrote:looking good - what PIPES & HEADERS! did you put on - what does it sound like?
Stephen
- trukcrazy
A lot of good work done there. Stay safe and have a nice drive. (I drove my 67 from Florida to California and back and had a great drive) Take care.
John, #424
1967 F250 crewcab x 2.
2008 Challenger SRT8
- Orange Beezy
Lookin good man.Did you have to do any mods for the f600 cluster?What did the radio set you back?
Bill
Bill
Looking good man!! That F600 cluster looks really good that's one thing I really really wish I would have saved when I got rid of my 70
60 Mercury Comet
65 Ford Econoline
77 Ford F250 "lowboy" 4x4
09 Harley Xl1200c
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
- SoCalExile
- Florian
Wow! That´s a lot of blue! Are you one of these guys?SoCalExile wrote: [ Image ]
Just joking You did an awesome job on that truck!
1971 Ford F100, 302cui, 3 on the tree
- SoCalExile
LOL.Florian wrote:Wow! That´s a lot of blue! Are you one of these guys?SoCalExile wrote: [ Image ]
Hell couldn't have done it without the site.
