Can I swap a Dana 21 for a NP205?
- F10YRB12118
Forum,
Perhaps this has been addressed elsewhere, I apologize in advance if I missed the thread during my search. I want to swap out my leaky old Dana 21 with an unknown NP 205. I own a 1972 F100 4x4 with a Dana 21 hitched to a NP435 behind a 360. I just acquired a running no rust 1973 F250 4x4 with a NP 205 behind a 3 speed auto with a 360 for $200.00
I have gone over many agonizing hours debating whether to keep the 72 F100 or keep the 73 F250. All in all, I think I'll keep my F100. I like Bumps more than Dents.
Does anyone know if I can drop the Dana 21 and bolt up the NP 205 from the 73? What challenges or issues might I have? Has anyone done this before?
Thank you,
Thank you,
Sean
1942 Chevy Truck, 1.5 Ton, G503
1967 F100 352 LWB Custom Cab
1969 Bronco Wagon 302
1972 F100 360 SWB 4x4 XLT
1972 F250 360 LWB Parts Donor
1973 F250 360 LWB 4x4 Donor?
1979 F250 460 Parts Donor
- Eric L
Re: Can I swap a Dana 21 for a NP205?
It can be done but it's not going to be a bolt in. sorry, but I dont have any specific info on the swap, but the trans (or at least the adapter and maybe shaft) is different. plan on crossmember and floor mods. and probly rework the drivelines. a Dana 20 from a early Bronco is also possible with adapters from Advance.
My '70 F-100 has a 205 behind a 435 out of a '78 Bronco, but I didnt do the swap. I can tell where things have been modified.
Eric
Edit: the '73 is gonna be a divorced case which makes it a poor candidate
Eric
The 205 from the 250 is DIVORCED. Your D21 is mated. No, there's no chance in hell of them interchanging.
- F10YRB12118
Eric L & Averagef250,
Thank you for the advice. I was afraid that might be the case, just the divorced vs. married issue was going to be hard to overcome. Eric L can you tell more about how your swap was done?
Thank you for your comments. It sure shows the advantage of forum.
Yours,
Yours,
Sean
- Eric L
I dont have much in pics at the moment.. but it would seem someone used a trans and transfer from a F-150 or FSB, bolted them to the bellhousing, made a goofy mount at the trans x-member, chopped a larger hole in the tunnel cover to accommodate the differences in the shifter/pattern. clutch & linkage should remain the same, driveline lengths may change, exhaust clearances may get tighter depending on what's in there now. note the yokes on a "new" transfer case may not match or interchange with what you have now. Ford used a few different yokes depending on the application.F10YRB12118 wrote: Eric L can you tell more about how your swap was done?
Eric
- 72Highboy
Hello F10YRB12118,
If you decide to get rid of that Dana 21 let me know. I know they are a week transfer case but a weak transfer case is better than no transfer case at all.
Joshua
aka Young Gun
FE - Famous Engine
(Brandi) 72 F100 360 5.9L Sport Custom 6" Lift
U.S. Army Veteran/11B
aka Young Gun
FE - Famous Engine
Hey there, are you looking for a dana 21 case because I got one in my 71 f100, I will be changing it over to a 205 set up.72Highboy wrote:Hello F10YRB12118,
I don't know what shipping would cost.
67 Highboy with 427FE 79 dana 60 front dana 70 rear 13" of lift 38" swampers. 72 F100 2wd short bed 302 toploader 4speed. 71 F100 shortbed 4x4 rust bucket. 68 F100 2wd long bed parts truck no rust.
What size is the bolt head that holds the np205 shifter to the np 435 case? all i had with me was a cresent wrench and it was too small.
F10YRB12118-
Yes, you can put a NP205 in your '72 F100, but it will have to be the married type and you'll need the transmission too. Here's a link to a "how to" on installing a NP205 in a '71 F100 http://www.fordification.com/forum/view ... =9&t=50999
Fordman-
If I remember right its 1 1/8", and most crescents only go to 1".
Fordman-
ok i have a 1 1/8 wrench. i just didnt want to drag a whole handfull of wrenches out there with me.
