C6 owners...
Re: C6 owners...
angle should be fine, the 4x4s are at a bad angle.
- OldRedFord
Re: C6 owners...
My next question is where should the center line of the transmission be? Being that the long tail housing hs those odd ball mounts I would like to drill some holes in the crossmember for the mounts. But I want to make sure the center line of the end of the transmission is in line with the rear end.
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
Re: C6 owners...
the easy way to do it is to put the engine and transmission in and then hold the crossmember up in place and that will give you a close center. to make mounts for the trans. as well you could also hook up the driveshaft to line it up with the rear end.
- OldRedFord
Re: C6 owners...
So tonight I am looking at C6 transmissions on Craigslist and I find no less then three with the super long tail housing like mine. None with the shorter housing.
Tim
- BobbyFord
Re: C6 owners...
I bought a 429 passenger car C6 and swapped in the short tail shaft from my FE C6.OldRedFord wrote:So tonight I am looking at C6 transmissions on Craigslist and I find no less then three with the super long tail housing like mine. None with the shorter housing.
- basketcase0302
Re: C6 owners...
- evan_flatt69
Re: C6 owners...
What are the pros and cons of a short-tailshaft vs a long tailshaft? Were the short tailshafts designed for use in trucks and the long tailshafts for cars?
1969 F-100 Short Bed Custom Cab 390
1985 BMW 635CSi
1985 BMW 635CSi
- forrestbump
Re: C6 owners...
Depends on LWB vs SWB. LWB has a slip joint in the center support bearing therefore a flanged, short, tail shaft is best for this application.evan_flatt69 wrote:What are the pros and cons of a short-tailshaft vs a long tailshaft?
SWB can use a long tail shaft with slip yoke since there is no center support bearing with slip yoke.
That's my understanding. Could be wrong as I often am...evan_flatt69 wrote:Were the short tailshafts designed for use in trucks and the long tailshafts for cars?
Larry
Larry
Re: C6 owners...
Or use the long tail shaft with the slip yoke and do away with the center bearing and go to a one piece drive shaft.
clint
clint
71 F100 SportCustom
460 C6. Disc Brake/Power-steering/automatic Swap. 3.00
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
Re: C6 owners...
A lot of long tail C6's came from Lincolns, which has a small servo and a soggy shift pattern.
I posted earlier on how to tell what 2nd gear servo you have in both C4 & C6's & much to my surprise, There was NO response ........................Donnie
