My 1972 F-100 Apr17 update
- robroy
Re: My 1972 F-100 Jan20 update
Good evening Dan!
The work you've done on your truck is truly amazing. Based what I see in the photos, you make it look SO easy! Of course I suppose what we don't see are the million hours of work that go in between each photo session and thread update.
Still, it looks like you're experienced with restorations, to say the least. How did you get this experience?
Thanks Dan!
Robroy
Thanks Dan!
Robroy
- basketcase0302
The truck's looking good man!
- knightfire83
Your doing a great job, thanks for sharing all your hard work!
That rear marker light fill mod is sweeeeet
1970 Ford F250 4x4 ~ Sold.
- robroy
I agree completely! As far as Bumpside body modifications go, I think that one's unusually stylish. Well done!knightfire83 wrote: That rear marker light fill mod is sweeeeet
Robroy
Really like the rear bed treatment.
Larry
Larry
- dantheman71
Thanks for all the compliments guys. Always hated the look of the rear running light anyway, couldn't find a more modern led light that would fit properly so that is the idea I came up with.
Here is a shot from the other side (of course still got some final touches to make!!
1972 Ford F-100
2002 Ford F-150
2002 Yamaha Raptor 660
Check out my NEW build thread: http://www.fordification.com/forum/view ... 93#p641993
2002 Ford F-150
I can say first hand that the cover for the side marker light looks good and should give it a one of a kind look. Are you going to stick with the lightning wheels? I am going to keep a eye on Dan's project and if you want to show off the paint when you get it done just let me know when to come and see it again.
- dantheman71
I don't plan on using the Lightning wheels, not forever at least. Once it comes back from the paint shop I might put them on so that it looks pretty sitting in the corner (while I save some cash), but I would like to eventually get some torque thrust 2s or some coys or something in a 5 spoke pattern.
I will give you a shout when it is getting close to completion. Hopefully it is worth the trip
1972 Ford F-100
2002 Ford F-150
2002 Ford F-150
Truck looks awesome Dan.
I just saw 2 years worth of your work in 5 minutes depressing huh
When your done drive it down to FLAMES country where it will be appreciated
- dantheman71
I will do that. I grew up in Calgary so I am really enjoying watching the Oilers lose again tonight.KF100TK wrote:Truck looks awesome Dan.
1972 Ford F-100
2002 Ford F-150
2002 Ford F-150
- dantheman71
Re: My 1972 F-100 Feb15 update
I finally completed the work on my frame. Completely disassembled it, got it sandblasted, then primed it and painted it. Just need to add a few more things like brake lines, fuel line, sway bar, front shocks, and it will be ready for the body to go on. Here are a few pics:
During disassembly
All parts sandblasted and ready for primer
Priming completed
Paint completed
Suspension and fuel tank installed, rolling chassis again. Tires turned for that car show pose.
Stayed tuned, more to come
During disassembly
Priming completed
Paint completed
1972 Ford F-100
2002 Ford F-150
2002 Ford F-150
Wow! Your frame has a better paint job than my car does.
- dantheman71
Thanks Brandon,
Although it is probably obvious from the other pics I also swapped out the fuel cell I had for a Mustang tank. It holds 2 extra gallons and to me it looks more like it belongs there.
1972 Ford F-100
2002 Ford F-150
2002 Ford F-150
- robroy
Good evening DanTheMan71!
I admire you for being bold enough to paint the chassis that bright color! It looks truly extreme in an excellent way--it's a work of art. You'll have to take about a thousand quality photos of it before taking it out on its first drive on a bumpy gravel road!
Robroy
Robroy
- convincor
Question on the new replacement wheel wells. Are the formed one piece? reason I ask is I have a older set that are made from two pieces, the top and the sides being a seperate piece. Where did you get yours??dantheman71 wrote: Bigger wheel tubs
during:
done:
"Still Plays With Trucks"
