- FormerMarine1981
- fomocoguy
Re: 1969 Ford Crew Cab / Cummins Project
I wonder how many hours of labor will be invested in this truck.... HRDROKN, you are keeping track, right?
Joe
1971 F100 flareside 8ft
2006 Dodge Ram 2500 cummins
2005 Ford Ranger
2005 Ford Ranger
- HRDROKN
Worked on getting the twins assembled today... what a PITA! There just isn't much room to do anything and the fit is so dependant on all the factors being just right. I also polished out the S400 compressor and still need to build the cold pipe....
- HRDROKN
Oh, BTW......
Looks the holiday screwing off is over also and I feel that I'm about fished out now. So I started working on some miscellaneous stuff before diving back into the suspension!
Gauges....
Gauges....
- BobbyFord
- 1971ford
WOW.... is that a F600 panel with the center cut out with your own sheet work? That is super slick.. I'd like to do the same.
- HRDROKN
I think that was the stock F250 panel.... heck, it's been so long I forgot what it originally looked like! Yes, I cut the center out and fitted a new .125 aluminum center section.1971ford wrote:WOW.... is that a F600 panel with the center cut out with your own sheet work? That is super slick.. I'd like to do the same.
- 1971ford
Nice. I thought it was a f600 cluster becaues of the chrome inside but now that i think about it the originals probably do have the chrome too.
- HRDROKN
Out with the vacuum assist and in with the hydroboost....
- 82GT
- sport71
when are you going to finish this awesome truck?
Those who do not learn the lessons of history, are doomed to repeat it.
- HRDROKN
Probablly never finished..... but I do expect to be driving her this summer!sport71 wrote:when are you going to finish this awesome truck?
What hydro boost did you use?
- HRDROKN
That hydroboost is a 91-97 F250/F350 application.... just had to rotate the bracket 180* and re-drill two of the holes. My peddle height will be about the same as it was.mljjones67 wrote:What hydro boost did you use?
