LANCE65 wrote:I have a couple of questions. On the rear corner tabs,do they sit the tank frame up about an 1/8" or does the whole frame lay flat on the truck frame? Thanks,and BTW looks GREAT!
-Lance
The tank frame sits up in the rear the thickness of that metal nut hole pictured above.
That is actually the bottom side of the tank frame that you see; that nut hole secures the rear of the tank frame to the truck frame. The rear-most bolt seen below bolts the rear crossmember to the truck frame, the bolt just forward of it is the rear tank frame mounting bolt:
On the sides of the tank frame, where the access holes were made to weld in nuts, flat stock was tacked along the sides to cover up the access holes and add ridgidity and overall strength to the tank frame.
