any pictures of p.s. box for a 78 4x4
Moderator: Doug Comer
- tex1264
i got a 67 4x4 frame swb, its got disk up front and p.s. i'm thinking they are off a 73 up truck maybe 78 i'd like to see different type p.s. box pictures and front rear pictures i'm new to 4x4's so be nice
thanks kevin
- 460 crew
re: any pictures of p.s. box for a 78
Here are pics from my 77.5 4x4 crew of the steering. You can see hao it has 4 mounting bolts and the crossmember is set in there at an angle instead of straight like the highboys. If you need any more let me know.
- 460 crew
2 more
- tex1264
this truck i have, has the p.s. box mounted on the outside of the frame& is mounted almost level thanks kevin
