1971ford
Re: 1971 f250 DESERT truck- 8/30 loTesting
Post by 1971ford »
First off, here is an update of what i did before the race.
-added 6 cage gussets
-added drive shaft loop out of a limit strap, Thanks to Mike Koenig for that :D
-added First-aid kit
-added floor mats to keep heat out of cab and rattlecanned the floor black
-other stuff im forgetting
RACE UPDATE :D
We got there Friday afternoon in the truck and swapped tires/coil springs. We then went to pre-run the course. We were told by many racers that the first 10 miles are really rough so we went ahead and checked it out. It was ROUGH. More like a jeep trail than a desert track, definately the most rough course out of the VORRA courses. Great way to start off with desert racing in a almost stock truck... Anyways we crawl through the ten miles and then there is a silt bed right before check point 1. we get through it but my brother's bronco (he tagged along to tow us out if we get stuck) died in the middle of it all. So we towed it off the course and picked it up the next day with the trailer that we had Rick Massie bring up for us (Thanks Rick!). As i was sitting on the center console to fit us three in the truck to get back to the pits, it starts raining. We turn on the wipers and smoke starts coming out the dash. We bail out and it stops when we shut all power off. Turns out the radio almost made a nasty fire. so i yanked that thing.
We asked to start dead last and we did. Then we got passed by the golf cart (Rhino) which was embarassing :D ,it had to start behind us.
We continue through the rough trail and pass mile marker 5, then we see the wall. A steep hill with huge rocks to climb over. So we are thinking of what route we will take up it when we arn't paying attention and swing wide on a turn, and instantly sinking the rear tires. So we break out the jack and start shoving rocks under the left rear. Then we more to the right rear and the jack breaks! Note to self: Stock, car scissor jacks don't belong on desert trucks. We radio in and main pit says they can get a floor jack in Chris's bug, 535, and he can dump it off so we can get going. Everyone then loses contact with him, darn. Looks like we will be there for 7 hours... meanwhile i watch cars slam my truck :( .
Then another truck comes by (748, thanks!) and has a hard time climbing the hill, then they get out and take a look at things on top of the hill. They let me grab their jack and we start trying to get it under the axle but before we do that, one of the King Of Hammer rigs (199, thanks!) comes at us... on fire. We flag them and put there fire out. We then use their hi-lift jack to jack the whole rear end up, shove rocks under, and we get out of there.
Then 5 more miles or rough trail.... Then we hit the silt bed right before check 1. We are moving steadily through the silt at a good speed and then out of no where we stuff the truck and a wall of silt turns the inside of the cab black and completely covers the windshield. we keep going straight and it clears. We then hit Check 1 and call it quits, and here ist he list of why:
-No jack, meaning if we get a flat or get stuck we are done, and going to have to wait for 6 hours
-tires rubbing fender wells: before the race we swapped another set of wheels on and the rim offset stuck the tire into the fender
-bed was falling apart: both bedsides are leaning way out, my braces broke
-blown front right shock, left front coil popped out a little
-my door wouldnt open from being hit, we got it open later
-a long, deep silt bed ensued, we would of got stuck for sure considering all the others who couldn't make it through as well
I'll consider Hawthorne a testing for Yerington of next season :D
Pictures!
Sexy.
The parade:
The launch..... more like sink
The action shot thanks to y2kbaja
Sitting at check 1 where we stopped. Picture thanks to Russel
spent a couple minutes scrubbing tire marks away, and using the last tiny bit of rattle can i had to cover up the scars. Also the big bed dent pushed right out. This picture makes it look alot better than it is because of the way the sun is hitting it.
Thanks to all that helped
We just watched the in-car video and it is okay. you can't see the trial because of the front end being high but you can hear us and the radio, and you can see inside.
I will be putting it together and getting it on youtube soon.
rjewkes
Re: 1971 f250 DESERT truck- First RACE!!
Post by rjewkes »
Cool you got out and raced though. so i guess a desert truck iether doesn't last long or gets pretty banged up over time.
fuelly.com
1971ford
Post by 1971ford »
well usually you arn't stuck in turns getting hit. Its not the truck that doesn't last long it is the parts that don't last long.
1971ford
Post by 1971ford »
:D
TheEskimo
Post by TheEskimo »
Man, now that looks like fun. Can't wait for the video!!!
-Jason
1972 F250 Camper Special 360ci
1973 F100 Custom 390ci
1985 Thinderbird 302ci (DD)
dolinick
Post by dolinick »
Wow, that is awesome! I bet yall had a lot of fun. I am looking forward to seeing more about your racing truck in the future.
Dan
2003 7.3L F250
1968 F500 Utility Truck
aramil
Post by aramil »
looks cool, other than getting stuck and everything how did the truck run? any cooling problems?
FormerMarine1981
Post by FormerMarine1981 »
Good job Ryan, and great pics. Sorry about the scrapes but she still came out alright.
taylor351
Post by taylor351 »
I'm pretty sure those will buff right out, Ryan.
Keith
2004 Dodge Ram 1500 Quad cab 4.7 liter Daily Driver
1993 f150 351 4x4
1969 f100 Ranger daily driver wantabe
1972 classic c10
Proudly serving Christ since 2000
God bless our troops
A bitter rural American clinging to my guns and my religion.
1971ford
Post by 1971ford »
yep we had tons of fun! I am so excited for Yerington but that is 8 months from now :(
Oh well, the truck will be a beast by then :D
Thanks guys
We had no cooling problems at all, it ran 210 and under the whole time. oil pressure was at 50 most of the time.
video:
http://www.youtube.com/watch?v=voSufGdjaFM
1971ford
Post by 1971ford »
Looky here :wink:
Dusty Times magazine, just about every offroad racer has it :woohoo:
robroy
Post by robroy »
Hey Ryan that is excellent--you are now even more famous than before! Congratulations!
Robroy
TheEskimo
Post by TheEskimo »
:thup: Sweet!!! :thup:
-Jason
1971ford
Post by 1971ford »
Thanks :D
Update...
I bent the i-beams. I measured at the beam pivot and came up with 5" of lift from my coils, so we pie cut them at my work and raised the end up 5" to get rid of the positive camber it had. Then my boss welded them back up, and plated them. It now has negatice camber, oops. BUt it is much better than it was before and when we put coilovers up front we will get rid of the negative camber.
It also dropped the front end down about 2 inches
I get my liscense in a week and this is my daily driver, so i have began to clean it up a little and make it slightly more luxurious, and more legal.
First i added down turns to the exhaust. This should greatly help with getting the rest of the exhaust out of the cab, and i also noticed a huge difference in the sound of my truck. I like it a lot more.
These set me back free dollars :D
I then whipped up a jack skid plate, so i can mount it just in case i get a flat...
I will probably mount it here. I need to pick up 2 more bike locks, one around the jack and one around my other spare tire.
I took the leaf blower and blew out a desert's worth of sand, then i vacuumed, and windexed everything. SO clean i don't even want to take it off of a road any more :D
I also cut off the GPS mounting tabs in front of the passenger seat on the cage, because they were just waiting for someone to not put on the shoulder belts and have those tabs go through there skull.
I also did some other small things, like i remounted the passenger side mirror that was broken off, and i also replaced the missing passenger side turn signal up front.
Fordnatic
Re: 1971 f250 DESERT truck- 11/29
Post by Fordnatic »
I was always told those beams were tempered and couldn't be welded on. I guess if your boss is a welder he should know what will work.
55F100
