Transfer case upgrade
67nukeford
Post by 67nukeford »
I have the NP435 and single speed transfer case in my 67 4x4. Is there a 2 speed transfer case I can upgrade to? I was going to go to a 5 speed, but can't find one that will adapt to my 390 without costing a fortune. So, I'll stick with the NP435 (and maybe have it regeared, if possible), but I'd like to get a 2 speed transfer case. Is there one available for the NP435?
Thanks!
Pat 1967 F100 4WD
LINK TO PROJECT THREAD
:http://www.fordification.com/forum/view ... &sk=t&sd=a
67F110
Re: Transfer case upgrade
Post by 67F110 »
I think the Dana 20 out of an early Bronco with an adapter will work. Do a search in this forum and see what pops up. It's been done.
cep62
Post by cep62 »
You could also get a NP435 with a 205 gear drive out of a '76-'79.
You'll need the tranny because yours is a 2wd with a adapter.
The D20 would be a good choice and it even has a lower ratio, but it might cost more to covert.?
67nukeford
Thanks cep, I think that will be the direction I go. I need to find a donor for the power steering anyway, now if I could just find a truck with a good tranny and transfer case to donate with it!
Pat 1967 F100 4WD
hazelnut
Post by hazelnut »
the bump F250 4X4s come with 2 speed cases,dana 24s should bolt right in.
Redcap
Post by Redcap »
Divorced or married?
Definitely skip the Dana 24 (piece of crap) and head straight for the NP205, which is available in either version.
67nukeford
Married. I've heard that about the dana also, so I'll stick with the 250.
Pat 1967 F100 4WD
shaggys_bump
Post by shaggys_bump »
1970 F100 Ranger XLT SWB 302
2004 Nissan Murano
1998 Isuzu Amigo "v6 4x4 conversion comin soon"
eggman918
Post by eggman918 »
Dana 24, I just rebuilt mine at 750,000 miles, I have nothing bad to say about a 24, but they are getting hard to find. However if you have over 450 hp it would be worth finding a NP205.MY truck has a stout 390 and lives in 4WD . Oh well free advice...... Good luck :thup:
4x4freakfe427
Post by 4x4freakfe427 »
[quote="cep62"]You could also get a NP435 with a 205 gear drive out of a '76-'79.
Go with what this guy said mid to late 70's 4 speed and 205 case, but you will have to lengthen the front drive shaft or get the donor one and shorten the rear shaft or get the donor one to. I cant remember if you have to modify the cross member. I am in the prosess of doing this same thing on my 71 f100 shorty.
67 Highboy with 427FE 79 dana 60 front dana 70 rear 13" of lift 38" swampers. 72 F100 2wd short bed 302 toploader 4speed. 71 F100 shortbed 4x4 rust bucket. 68 F100 2wd long bed parts truck no rust.
Redcap
Post by Redcap »
eggman918 wrote:Dana 24, I just rebuilt mine at 750,000 miles, I have nothing bad to say about a 24, but they are getting hard to find. However if you have over 450 hp it would be worth finding a NP205.MY truck has a stout 390 and lives in 4WD . Oh well free advice...... Good luck :thup:
:roll:
