Went Shopping
Wes
Went Shopping
Post by Wes »
Well Saturday I was redoing the return line to my remote power steering/brake reservoir, and I noticed the front left tire had separated. This tire was so bad I couldn't drive the truck around the block w/o losing my fillings. :cry:. So I bit the bullet and got some 37 12.50 mil spec Hummer take offs I found on CL , I also picked a np205 to replace my Dana 24. I spent a few dollars, got got the T-case at fair price, the tires @ normal for this area. I will get 1 more for a spare. Next time this beast needs tires I hope to upgrade to 18" rims w/ 37's.
The 37's seem to work well with 4.56 ring and pinion, no freeway yet. Will hit the highway after I dial in the alignment and get a steering stabilizer.
Here she is in her new shoes :D
Wes
67 F250 High boy
69 Bronco
Doug Comer
Re: Went Shopping
Post by Doug Comer »
Looks good.
Doug
1967 f100 4x4
1970 f250 4x4
fomocoguy
Re: Went Shopping
Post by fomocoguy »
Nice! How much lift do you have? Any clearance issues?
Joe
1971 F100 flareside 8ft
2006 Dodge Ram 2500 cummins
2005 Ford Ranger
Wes
Re: Went Shopping
Post by Wes »
I added 4" skyjacker springs front and rear w/ factory blocks in rear. I think at max flex, the fronts might hit the front corners. I haven't had a chance to "exercise" her.
Wes
67 F250 High boy
69 Bronco
fomocoguy
Re: Went Shopping
Post by fomocoguy »
Thanks! If I ever lift mine it will probably be 4", so now I know what to expect. :thup:
Joe
2005 Ford Ranger
frankensteined_67
Re: Went Shopping
Post by frankensteined_67 »
wes nice truck. just wondering if you could do me a quick and easy favor can you tell me the the height of your bed rails to the ground. im building a f100 with 8" of lift and i think it should be the same but not sure. thanks man
Wes
Re: Went Shopping
Post by Wes »
frankensteined_67 wrote:wes nice truck. just wondering if you could do me a quick and easy favor can you tell me the the height of your bed rails to the ground. im building a f100 with 8" of lift and i think it should be the same but not sure. thanks man
61" from the ground to top of bed rails
Wes
67 F250 High boy
69 Bronco
frankensteined_67
Re: Went Shopping
sweet thank you that is what i was shooting for :woohoo:
