HRDROKN
Re: 1969 Ford Crew Cab / Cummins Project
Post by HRDROKN »
And here is the latest on the stand alone clutch peddle assembly..... this will hold the clutch master cylinder for my 3600# double disc clutch. I will add a third bearing suport to the outside of the shaft and finish off the M/C rod end mount.
:D
HRDROKN
Post by HRDROKN »
In between the porting action... I had this adapter/spool piece made to bolt the NV4500 to a NP205 (Ford case w/Dodge gears).... Then I read a thread about the cast iron tail housings on CompD, so I need to check my runout!
:thup:
HRDROKN
Post by HRDROKN »
Hey Dustin,
I'm thinking we may have talked about the NP205 vs NP241 some time ago, so forgive me if this is redundant. Do you know what the overall width of a NP241 is? Trying to remember if it fits within the frame rails... this is what got me thinking about this again....
NP205 destructs on a pulling truck.....
:eek:
averagef250
Post by averagef250 »
The dodge 241 is 3-4" wider than a 205. The GM IFS 241/242 is about the same offset, but clocked flat.
I don't know the story behind that 205, but would stand behind a 205 being stronger than a 241. If I had to guess what happened to cause that 205 to come apart I'd put money on the reason being that it's a divorced unit. The divorced cases have far more stress going through thier case than a mated one. If you mount one too cushy you'll spit yokes, if it's too rigid the frame torsion will split the case.
If I had a dedicated pulling truck I'd do what the monster truck guys do- Build a dedicated full time chain reduction box.
HRDROKN
Post by HRDROKN »
Studs are in and the head is on! :thup:
:woohoo:
HRDROKN
Post by HRDROKN »
Made a little modification to my remote filter plate..... tap'd out the turbo oil feed to 3/8 NPT. The plan is to feed both turbos through this port.
:hd:
HRDROKN
Post by HRDROKN »
Today I got the AirDog150 mounted in place....
Brought in my new fuel tank/tool box from the shed. Ordered up some more fittings and some rubber isolators to mount the tank....
Here is the fuel door that I will be tying into the tank fill......
:thup:
71cc
Post by 71cc »
I am interested in the filler door, lets see some more pics. Where did you get it? I will follow along to see how it fits the contour of the bed.I need to do the same thing for the tank I added behind the axle.
HRDROKN
Post by HRDROKN »
71cc wrote:I am interested in the filler door, lets see some more pics. Where did you get it? I will follow along to see how it fits the contour of the bed.I need to do the same thing for the tank I added behind the axle.
I was really surprised to see just how close the contour actually is.... I ordered it with the front face un-welded just in case I need to tweak the fit some.
:wink:
HRDROKN
Post by HRDROKN »
Getting the head studs all torqued.....
My Boy got skills.....
Chicks dig guys with skills.......
:lol:
shaggys_bump
Post by shaggys_bump »
sorry if someone asked this already, what brand and type of paint did you use. it looks like the paint is textured but is that just the texture of the block?
1970 F100 Ranger XLT SWB 302
2004 Nissan Murano
1998 Isuzu Amigo "v6 4x4 conversion comin soon"
HRDROKN
Post by HRDROKN »
shaggys_bump wrote:sorry if someone asked this already, what brand and type of paint did you use. it looks like the paint is textured but is that just the texture of the block?
Ya... the texture is from the block. The paint is Summit Ford Blue engine paint.
:wink:
HRDROKN
Post by HRDROKN »
Got a few miscellaneous things accomplished...
Hard piped the fuel supply with 5/8" tubing and -10AN fittings and is gravity fed from the 51 gallon tank.
HRDROKN
Post by HRDROKN »
Well after much thought.... I decided to ditch the NP205 transfercase and go with a NV271.
I will be boxing up the frame in the near future (already started cutting and fabing) and will just use a half round to close up this cut out...
:wink:
71PA_Highboy
Post by 71PA_Highboy »
OK,
I'll bite... why the change in the T-case? That one looks chain drive, so I am confused.
TIA,
Eric
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
