Where do "Service Specification" & "Emission" stickers go??
It looks like the service spec sticker goes on the outboard surface of the drivers side valve cover, towards the front of the valve cover.
Where does the emissions sticker go?? (LMC part 42-0653)
Thanks!
Ben
Thanks!
Ben
Re: Where do "Service Specification" & "Emission" stickers go??
if its the one im thinking of yes that is where it goes.
What I am not sure on, is where that emissions sticker goes.......I saw it on the air cleaner snorkel front facing surface in somebody's forum pic....but it didn't look at home there......
ok it is the sticker i was thinking of. its the one with the spark plug gap size and all of that on it. it does go on the frotn drivers side valve cover. the air cleaner was wrong. i have never seen a emissions sticker on a air cleaner. only the orange engine size sticker.
- flyboy71
Yep I believe youre right.
-Jeff
- court1100f
Man that is a seriously clean gorgeous looking engine in that picture!!!!!
- flyboy71
Thats the truck on the index page of this site, with 358 original miles. Cant get any more accurate than that. I get giddy every time I look at those pics.
-Jeff
- 91Bear
So, where does the emissions sticker go?
on the drivers side valve cover
- 91Bear
Oh, I thought that was the Service Specification sticker. Where does the other one go? On the door?
- 91Bear
nm
its the same sticker all in one.
I'll post a picture of the two different stickers.....when I get home tonight....
Since I couldn't figure out where they both went, I put on on EACH valve cover.
They are definitely different....
