carb gaskets
newb70f250camper
carb gaskets
Post by newb70f250camper »
would like to know if the carb gaskets in picture are correct if i use the spacer to intake gasket the intake sucks in air a point "A" . if i use a carb to spacer gasket do i need to plug holes "B" "C" "D" :hmm: any kind of help would be appreciated :fr:. also should the numbers be facing up to sky or down to earth? :pray:
1970 f-250 camper special, 360, holley P/N 0-80457S (electric choke) 4v carburetor, edelbrock performer390 intake. I love my truck like I love my women.
sacramento_ford
Re: carb gaskets
Post by sacramento_ford »
i used a on top and bottom
70_F100
Re: carb gaskets
Post by 70_F100 »
Actually, neither one of them looks right for use on the bottom with the spacer.
"A" will probably leak.
"B" has a lot of extra cut-outs.
"B" without cut-outs should be correct.
"A" looks correct for carb-to-spacer (right under the carb, on top of the spacer).
newb70f250camper
Re: carb gaskets
here is carb to spacer without the lettering are the holes ok or should i plug them some how?
convincor
Re: carb gaskets
Post by convincor »
just took one apart that I believe had never been touched.
Spacer to manifold the small hole is on the left side of the engine, although I don't think it would make a difference.
Spacer to carb has two gaskets (one of each) that seemed to be glued together.
The one that's the same as the spacer to intake is against the spacer with the small hole toward the right side then the other gasket on top.
"Still Plays With Trucks"
