What could go wrong that caused this?
JMcTurnan
Re: What could go wrong that caused this?
Post by JMcTurnan »
It was all one piece. I dropped a new distributor in there. It runs really well right now, but I won't know if something is foresure internally problematic untill this one gets grinded too. Because its almost brand new, bought it professionally rebuilt with limited lifetime.
JMcTurnan
Post by JMcTurnan »
Bam, now time to check out the timing chain stuff. Gear got stripped again, if people could try and give me a list of things i need to check on.
remove the timing chain gear and look for the spacer that might have been left in there.
JMcTurnan
Post by JMcTurnan »
Ill definetly do that.
JMcTurnan
Post by JMcTurnan »
Can someone tell me if an 89 mustang 302 timing chain cam gear has a spacer built in?
JMcTurnan
Post by JMcTurnan »
Because I believe the original gear on mine had the spacer built on.
Skifu
Post by Skifu »
Why do they still sell them with plastic gears,I could just kick the idiot that invented radiator plastic end tanks,Ive owned 2 vehicles that had them in it,and the both of them failed,same with plastic timing and cam gears!
94 Ford F-150 super cab
300-6 eod auto,changing to NP-435
JMcTurnan
Post by JMcTurnan »
So i asked my mechanic. He said on fords there are no spacer plates, and I'm like wtf. Does anyone know if the 77 351w fiber gear is a different thickness than an 89 302 gear? He said it isn't the gears most likely, but the oil pump seized up. If the oil pump seized up the 30 miles I drove it the last 2 times would of ruined the bearing. But Im going to double check the rod tommorow, then start pulling the timing chain cover.
