does a 72 full size passenger car rim fit a 69 half ton 2 wheel drive.
Thank you
rim and tire interchange
- 72hiboy4x4
the spacing on a 1/2 ton is 5 on 5.5 inch
I don't believe the car wheels will fit, being a smaller diameter on the spacing.
BUT there was a set of 5 on 5.5 ford white spoke wheels on craigslist a couple days ago for $40. might still be there.
here is a set for $175.00. I don't see the others
http://portland.craigslist.org/pts/93919766.html
- FORDification
- Site & Forum Admin
re: rim and tire interchange
No. With Ford trucks having the 5.5" bolt pattern, the only vehicles that have the same are Dodge trucks and Jeeps....oh, and IH Scouts.
- 71-F-250SC-72-F-250C
I want to put the new F-250 wheels on my truck, I believe that all the way up to 98 will fit.
71 f-250 Sport Custom-frame off in progress..again thank to irjetmachanic.
72 f-250 Custom
71 f-100 swb sport custom
03 mach1 mustang
cant forget my thing...haha 74 volkswagon thing.
[quote="ToughOldFord"]
Damn, 7 gallons per mile, obviously FE powered!
72 f-250 Custom
03 mach1 mustang
the center on ford wheels are different between cars and trucks. a care wheel will fit only on the back of a truck but not on the front because of the larger hub. i've never run on to bolt patterns that havent matched unless the car rim was a smaller car with 15 in rims. then have i seen a smaller bolt pattern.
