Pressure Washing
ccford
Pressure Washing
Post by ccford »
Whats the consensus? is it ok to pressure wash a motor while it is running with cold water? or do you risk cracking the block?
fitzwell
Re: Pressure Washing
Post by fitzwell »
If you just started it, i can't see where it'd be much of an issue. If you drive it a couple of hundred miles & decide to give it a bath, it might not end well.
fitzwell
Post by fitzwell »
Sam I Am
Post by Sam I Am »
It should be fine as long as it doesn't have aluminum heads or block.
It shouldn't hurt old school engines at all but you might want to cover the distributor with a Wal Mart plastic sack.
And instead of cold water, find a good car wash that heats up the water and it will clean even better.
i go to the car wash and do it. i also put a rag inside of the dist cap and put it back on while i wash it. take a can of wd40 with you incase the rag got wet. you can remove the rag and spray the inside of the dist cap to disipate the water.
72bumbee
Post by 72bumbee »
I could almost swear I killed my coil by pressure washing my engine while it was running. I had a baggie over the dist. and was mainly hitting the front and bottom of the motor.
“To succeed in life, you need two things: ignorance and confidence.”
Mark Twain
1972 F-250 Camper Special. 360 A/T P/B AND a DANA 60 Rearend!
Former owner of dads 1967 F-100. It has gone home to the big road in the sky...
i never leave mine run while i wash it.
sideoilerfe
Post by sideoilerfe »
If you wash it with hot water than it shouldn't be an issue. Hot water works better anyway.
1970 F250 4x4 390/4spd
1968 F250 4X2 360/C6/No Rust!
