FE heads question
- 69rangerf100
FE heads question
ok here it is. i found a set of 427 hi- performance heads off a 89 427 so the Craigslist add says would these heads work on a 69 390 block and what kind of mods would have to be done to have the engine perform correctly
David
Dream as if you'll live forever, live as if you'll die today - James Dean
Daily Driver - 1998 Honda Accord
Wife's Ride - 2007 Ford Explorer Sport Trac
Project - My Dad's 1969 F100 Ranger 390 w/ 3spd manual coming soon PS, PB, A/C and alot of paint and body work - Miss you Dad
http://s936.photobucket.com/albums/ad208/69rangerf100/
Re: FE heads question
An 89 427?
If it is an FE engine they will work depending on valve size you may have to slightly notch the cylinders for clarance.
Of course I wan't aware of any FE's built that late so any number of changes might have been made for a boat, irrigation or industrial motor...
yes it could be from a ft engine. if it is from a ft engine it may not work on a fe engine because of the location of the water jackets in the head and block. they are in different places.
- 69rangerf100
the more i thought about it after i posted this, they may be gm heads i have email the seller to find out.
David
