engine mounts.
hotrod ford
engine mounts.
Post by hotrod ford »
can fe mounts be used for in inline 300 and vice versa?
convincor
Re: engine mounts.
Post by convincor »
if you mean the perchs themselves, yes. http://www.fordification.com/enginestands.htm
if your talking the rubber mounts, no.
"Still Plays With Trucks"
hotrod ford
Re: engine mounts.
cool. this will work out great. while i work on my i/6, i'm goona tranplant a 360 that i have so i can run around town. thanks convincor :thup:
convincor
Re: engine mounts.
Post by convincor »
you will have to move them to the forward hole though.
and bell housing is different between the two.
Re: engine mounts.
here si what happens when you put an fe in a truck that had a 240 in it and dont move the moutns.Image the transmisson and drive shaft wont go back together. it will be about an inch or two to far apart. i know i forgot to move them. i was being rushed and forgot to move them.
