can't find water outlet 67 f250
tchrincali
Post by tchrincali »
Help! I broke the water outlet on my 67 f250 camper special 352. Are these available? If so, where????????? :eek:
george worley
Re: can't find water outlet 67 f250
Post by george worley »
you can get one off any 352-390 manifold it does'nt matter if its 2v or 4v. A member here may have one. Check the parts catalogs that have parts for 67-72 Ford trucks. LMC, NPD,JC Whitney.
post inthe parts wanted section. several people have extra ones. measure the size of the hose though. some of them use a different sized hose. ezernutt has two of them with different sized hose for them.
mrtleavitt
Post by mrtleavitt »
I have a '69 390 that should be the same as your 352 and Autozone usually has an original in stock. Give them a try.
BMJs 67
Post by BMJs 67 »
PM sent
Daily driver:
67 2WD, 390ci
