Carb Linkage help
grandpas1972
Carb Linkage help
Post by grandpas1972 »
Hello this is my very first post on these forums. Well i removed the old carb from my grandfathers 72 camper special and did not look at how the linkage went. So im wondering if there is some sort of diagram on how the linkage goes. any help is appreciated. Thank you
ezernut9mm
Re: Carb Linkage help
Post by ezernut9mm »
hope this helps.
ezernut9mm
or you can just do this.
grandpas1972
Thank You ezernut9mm. going out to try these today.
VirginiaCityFord
Post by VirginiaCityFord »
I'm just getting into my 72 that has a 390 with a 2v. Someone at some point has micky moused the carb, there is a steel line leading off the choke that has been squeezed shut for instance. Is there any kind of diagram like the one grandpas72 asked for?
cjroddam
Post by cjroddam »
hey im curious about this too...i didnt pay too much attention to mine when i removed the stock 2bb and now im ready to hook up my holley 4bbl...anyone have a pic of theres with a holley with the stock hardware linkage and how the kickdown is hooked up?
convincor
Post by convincor »
depending on the height of the intake you may need a kick down extension. http://www.summitracing.com/parts/HLY-20-41/
didn't use one here.
"Still Plays With Trucks"
cjroddam
Post by cjroddam »
cool cool...well im using the edelbrock performer rpm intake with a holley 4160 and a 1" carb spacer
