I am slowly rebuilding a '72 F250 Custom. I've got her running but the exhaust manifold is cracked. I ordered a new one from LMC. The problem is I am missing a few bolts and the rest our sketchy. I would like to replace them all but I don't know the specs of the bolts. I called my local auto store and they have bolts in stock (not for a '72 ford) to try and match up with. Can anyone suggest a solution besides spending $10.00 each at the dealer....
Thanks is advance.
'72 F250 Exhaust Manifold Bolts
Re: '72 F250 Exhaust Manifold Bolts
I would take one of the ones you have to a hardware store and have them match you up a few for 50 cents. Grade 5 will do just fine. The hardware store should have a little deal that you can thread your bolt into and it will tell you the size. Hope this helps.
Corbin
Corbin
Honestly, I really would rather push a Ford than drive a Chevy.
1969 F-100 4x4 Dana 44 w/ disk brakes and power steering conversion 390 c6 np205.
1970 F-250 97k original miles bone stock 390 np435 most original unmolested truck I have ever owned.
2001 F-250, Extra Cab, 4x4, 7.3 Direct Injected Turbo Diesel, Edge Programmer, Flowmaster 4" Turbo back Exhaust, 3" Leveling Kit with 33" Goodyear Wrangler DuraTracs, and has 250,000 miles and counting.
get stainless botls once you get the size of them. they will be easier to remove the next time if that time ever comes.
