What RPM's
FordTruck
What RPM's
Post by FordTruck »
What RPM's do your trucks run at between 30-45mph??
My trucks got a 302 with a C6 combo and I think 3:50 or 3:55 and it runs between if I rember correctly about 2000-2500 at about 40. That just seems high to me and I was wondering what may cause that or is that about normal?
60 Mercury Comet
65 Ford Econoline
77 Ford F250 "lowboy" 4x4
09 Harley Xl1200c
SteveC
Re: What RPM's
Post by SteveC »
my 67 with a 352 np435 and 4.11 gears runs around 2500-2800 at 55-60
of course tire size plays into this equation as well
1967 f-100 4x4
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
miner3do
Re: What RPM's
Post by miner3do »
mines a 390 with a four speed and at 45 mph im at 2000
1990 Mazda Miata 1.6 turbo
2010 Audi S4
1967 F100 4x4 4spd
FordTruck
Re: What RPM's
Post by FordTruck »
Thanks for the imput guys.
If it matters the trucks got 235/75R/15's on it.
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
green68250
Re: What RPM's
Post by green68250 »
That does seem high for that gear ratio and that size of tire. I know my F-250 with a c6 and 4.10's will do 65-70 at around 3 grand, I would say shes around 1800 to 2000 at 40mph.
Honestly, I really would rather push a Ford than drive a Chevy.
1969 F-100 4x4 Dana 44 w/ disk brakes and power steering conversion 390 c6 np205.
1970 F-250 97k original miles bone stock 390 np435 most original unmolested truck I have ever owned.
2001 F-250, Extra Cab, 4x4, 7.3 Direct Injected Turbo Diesel, Edge Programmer, Flowmaster 4" Turbo back Exhaust, 3" Leveling Kit with 33" Goodyear Wrangler DuraTracs, and has 250,000 miles and counting.
Fordnatic
Re: What RPM's
Post by Fordnatic »
2400 @ 60 with 3.50's and 31' (tall) tires
2400 @ 60 with 4.10's and 35" (tall) tires
are what my two F100's run.
So, yes tire size makes a big diff. There is a calculation page here: http://www.angelfire.com/fl/procrastination/rear.html
55F100
mrtleavitt
Re: What RPM's
Post by mrtleavitt »
My truck runs 1600 rpm @ 35 mph. 390 w/ T19 4 speed and 31 inch tires. That's as high as you'd every want to go with gearing imo.
FordTruck
Re: What RPM's
Post by FordTruck »
Thanks for all theimput guys so it sounds like it may be running a little bit high. What could cause that? I'm pretty shure its shifting into 3rd becasue 1st&2nd shift really soon.
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
SteveC
Re: What RPM's
Post by SteveC »
are you sure of the ratio in the rear end?? could it have been changed?
1967 f-100 4x4
FordTruck
Re: What RPM's
Post by FordTruck »
SteveC wrote:are you sure of the ratio in the rear end?? could it have been changed?
I'm pretty shure that's right because that's what the tag on the rear end said. I'll have to try and find that tag again just to make shure I got it right.
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
FordTruck
Re: What RPM's
Post by FordTruck »
Here's the numbers off of the rear end tag.
WDM-T 9N?
3.50 8 7 311A
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
Fordnatic
Re: What RPM's
Post by Fordnatic »
It's common to change the gears, so the tag may not be correct. Just use the formula on the link I posted and see what you get.
55F100
FordTruck
Re: What RPM's
Post by FordTruck »
Fordnatic wrote:It's common to change the gears, so the tag may not be correct. Just use the formula on the link I posted and see what you get.
I checked it and the link matches what the trucks doing. Just 3 grand seems like alot of RPM's for that speed. But its a small block so I guess it can handle the revs.
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
