427 oil filter adapter
- mrtleavitt
Has anyone put on one of these filter adapters to replace the stock unit. Apparently the oil passages are larger to improve the flow. The only ones that I've seen are for a vertically mounted filter which won't fit on the FE trucks since the big FEs always came in cars. Anyone know if a horizontal mount exists with the large oil passages?
- convincor
Re: 427 oil filter adapter
"Still Plays With Trucks"
- mrtleavitt
I have about 5 of those on the shelf but there is one original to the 427 that has larger oil passages. My brother bought one but it was the verticle mount style and it wouldn't fit on a truck. I have never seen a larger oil passage horizontal filter housing, that is what I'm looking for.
- convincor
I'll look around for the extra I have. I don't remember the holes being the small.
I've had a couple of the verticle style with the small and large port but remember the horizontal being just as big as the large port verticle.
Not to hi jack the thread, but why won't the vertical style adapters work on the trucks?
Daily driver:
67 2WD, 390ci
67 2WD, 390ci
they will work but then you cant remove the oil filter without jacking up the engine to get the filter off.
- sideoilerfe
The hiboy 4x4 FE's had the vertical ones.
1970 F250 4x4 390/4spd
1968 F250 4X2 360/C6/No Rust!
I have a 427 in my 68. I used the 428 adapter.I think its still available from Ford.Its got the bigger passages to flow more and bolts right up no problem.Hope this helps you out,Brian.
68 f100 427 r code 4spd toploader
69 f350 390 4spd hauler bed
72 Ford Bronco 302 3spd
95 Ford Lightning
38 John Deere G
Assorted old Honda ATC,s
95 Ford Lightning
38 John Deere G
- flyboy2610
Use a 3/4 quart Dodge filter. Same diameter and threads. Fits perfectly, but short enough to get it on and off.fordman wrote:they will work but then you cant remove the oil filter without jacking up the engine to get the filter off.
Red Green
you'd better be right.
Red Green
- robroy
Hey MrTleavitt,
I followed the advice of FlyBoy2610 and got the 3/4 quart filter; it works perfectly with no clearance problems. There are detailed photos of this in my project update thread:
http://www.fordification.com/forum/view ... 15#p387130
Thanks again to FlyBoy2610 for the helpful advice.
Robroy
Robroy
- flyboy2610
You are both very welcome! Glad I could be of help.
Red Green
Red Green
- mrtleavitt
Ya flyboy that's awesome! I ordered a verticle adapter today! Thanks!
