New Engine
70 Sleeper
New Engine
Post by 70 Sleeper »
I have a 70 with a 240 and I want to switch to a V8. I have located a 360 and a tranny and a 460 for the exact same price. I would like some insight on what you guys would do here. I am 27 and I am building my first truck.
Thanks
mrtleavitt
Re: New Engine
Post by mrtleavitt »
A 360 would be nice because it's less of a headache to get it to fit into our trucks. A 460 would be awesome for the power if you're up for the job. I've never stuffed a 460 in a bump but you would need the engine perches from a 460 Ford truck from a '73-'79 plus I believe there is some sort of issue with clearing the radiator. I know a few people have put a 460 in their bumps around here so hopefully they'll chime in. A 360 is nice because they came originally in these trucks and you would need the engine perches for a 352, 360, or 390 truck but wouldn't have to worry about any other clearance issue. So all said and done I would say the 360 since it's your first time plus it will give you lots of power but go for the 460 if you're up for a bit of a project.
papabug71
Re: New Engine
Post by papabug71 »
Welcome to the site from Oklahoma!! :wel: :fr:
So the 360 comes with a transmission & the 460 doesn't. Correct?? If the 460 dont come with a tranny, figure in extra cost & time to locate a transmission. As well as the different drive shafts for the different transmissions.
It all depends on what you want. Is it going to be a street machine or just a nice daily driver with a little pep?
I have never been a fan of dropping a 385 series motor in a bump, but thats just me. Call me crazy, dumb, whatever. To me its like putting a FE in a 80's era Ford truck. It just doesn't belong there.
My vote (at this time) is for the 360.
Good luck!!
Matt
Mine since 5/7/'94
302 / 3 speed / 3:25's
Re: New Engine
get the 360 and trans combo. it is a easyier engine to mess with and it has the trans with it. the 460 will take a different trans than the 6 cyl and the 360.
70 Sleeper
Re: New Engine
Thanks for the info guys. The truck is just a project, not a daily driver. I am calling about both engines today, so hopefully I can make a decision. What is the average price for these two engines in running condition? I think both are pretty good deals. I can get the 360/tranny for $300.00 or the 460 for $400.00
mrtleavitt
Re: New Engine
That sounds like pretty good prices to me. A 360 core at the junk yard is going to be $150 so I'd go for it!
papabug71
Re: New Engine
Post by papabug71 »
The 360/tranny combo for $300 bucks. Deff. the better deal.
Matt
Mine since 5/7/'94
sideoilerfe
Re: New Engine
Post by sideoilerfe »
mrtleavitt wrote:A 360 is nice because they came originally in these trucks and you would need the engine perches for a 352, 360, or 390 truck ...
The FE perches are the same as the 6 cylinder perches. You just need to move them to the rear set of holes.
1970 F250 4x4 390/4spd
1968 F250 4X2 360/C6/No Rust!
mrtleavitt
Re: New Engine
That's a cool bit of info! Thanks
nevrenufhp
Re: New Engine
Post by nevrenufhp »
Then sell the 240 on Fordsix.com
67 F100, 300(Offy intake, Edelbrock 500, 274*/.518" lift cam, heddder, duraspark & Summit CD ign), 4spd, power steering swap, front disc and hydroboost.
08 VW R32
increase diesel fuel rate site:
http://www.freewebs.com/nevrenufhp/index.htm
70 Sleeper
Re: New Engine
Update.. Talked my brother into selling me his 306 and c4. This should be a fun project.
Thank you guys for all of the input. :D
