Keep the 6(its not original)or 360?
oleman69pu
Post by oleman69pu »
The 69 f100 I bought is in bad shape...cab..floors..bed..the only thing thats good is the I-6..and its not the one that came in it..so what would you do?
Rebuild the 6..find a 69 I-6..or put a 360 W/air and p/s?? :? :? :help: :help:
69 F-100's Rule!
70shortwide
Re: Keep the 6(its not original)or 360?
Post by 70shortwide »
maybe find a truck thats in better shape to use the motor in?
convincor
Post by convincor »
70shortwide wrote:maybe find a truck thats in better shape to use the motor in?
:yt: that was my first thought.
"Still Plays With Trucks"
oleman69pu
I have found a cab so thats not a problem... :thup: ...so what would you do on the engine? I'm thinkin..360 :hmm:
69 F-100's Rule!
FreakysFords
Post by FreakysFords »
Were it me and the 6 was in good shape and was installed correctly, I'd leave it and have a fine torque happy driver / worker. That said, I'm a HUGE FE fan and there's always room for a good FE.
In other words there's no wrong answer to this question, so do the "work sheet" thing and decide what works for ya :)
example
1) 240 or 300 (either is a FINE engine) and what's it's condition
2) What's the KNOWN condition of the 360? (IE how much $ needs to be spent on oil leaks, carb, etc)
3) What all will need to be sourced to make the swap (assuming the 6 is in good order, weigh against).
4) what's more important to you as far as milage, feel, etc?
ToughOldFord
Post by ToughOldFord »
I'm a big fan of FEs, but with today's fuel prices I'd keep the six.
And a major plus is the ease of working on an inline six. :thup:
nevrenufhp
Post by nevrenufhp »
Even better part of the 6, besides easier to work on, is not having to work on it very much. :thup:
67 F100, 300(Offy intake, Edelbrock 500, 274*/.518" lift cam, heddder, duraspark & Summit CD ign), 4spd, power steering swap, front disc and hydroboost.
08 VW R32
increase diesel fuel rate site:
http://www.freewebs.com/nevrenufhp/index.htm
