Okay guys i rebuilt my carb for the first time. It was one hell of a experience.. never thought it had that many parts..
Finished cleaning it put a new fuel filter and all the goodies.. and put her back on.. cranked her up and vroooooooooooooooooommmmmmm.. turned it off.. scared the crap out of me.. i'm clueless as of why,, i'm guessing the throttle is stuck or something dunno..
need some help
- cablewarf
Re: need some help
Forget throttle return spring?
1968 F-250 / 300 six / T-18
Dana 60 - 4.10 Limited Slip
- cablewarf
Re: need some help
got all the springs hooked up..
Re: need some help
Did you adjust the idle screws at all during cleaning and reassembling? Just a thought.
Troy
Re: need some help
did you tap the gas pedal to let it idle back down. it may have just caught on soem of the linkages on the side of the carb. take a pic of it fromt he drivers side if it is catching and you can't figure it out.
- cablewarf
Re: need some help
i'll try and get a picture tomorrow.. i might need to adjust the screws.. didn't do that yet.. also the peddle is weird.. it's almost all the way down to the floor.. hmm weird
Re: need some help
When you look down the throat of the carb are your throttle blades closed? partially open? with your gas peddle nearly to the floor as you say something in the linkage is hanging you up i would think, just take a closer look and work the throttle by hand, it has to be something obvious.
Jim
'75 Ford Highboy 390 4spd
- FORDification
- Site & Forum Admin
Re: need some help
...or you have your spring installed incorrectly....that is, holding the throttle open rather than closed.
