need some help
cablewarf
need some help
Post by cablewarf »
Okay guys i rebuilt my carb for the first time. It was one hell of a experience.. never thought it had that many parts.. :o
Finished cleaning it put a new fuel filter and all the goodies.. and put her back on.. cranked her up and vroooooooooooooooooommmmmmm.. turned it off.. scared the crap out of me.. i'm clueless as of why,, :? i'm guessing the throttle is stuck or something dunno.. :hmm:
NM5K
Re: need some help
Post by NM5K »
Forget throttle return spring?
1968 F-250 / 300 six / T-18
Dana 60 - 4.10 Limited Slip
cablewarf
Re: need some help
Post by cablewarf »
got all the springs hooked up.. :hmm:
towtruckerfour
Re: need some help
Post by towtruckerfour »
Did you adjust the idle screws at all during cleaning and reassembling? Just a thought.
Troy
Re: need some help
did you tap the gas pedal to let it idle back down. it may have just caught on soem of the linkages on the side of the carb. take a pic of it fromt he drivers side if it is catching and you can't figure it out.
cablewarf
Re: need some help
Post by cablewarf »
i'll try and get a picture tomorrow.. i might need to adjust the screws.. didn't do that yet.. also the peddle is weird.. it's almost all the way down to the floor.. hmm weird :roll:
montana_hiboy
Re: need some help
Post by montana_hiboy »
When you look down the throat of the carb are your throttle blades closed? partially open? with your gas peddle nearly to the floor as you say something in the linkage is hanging you up i would think, just take a closer look and work the throttle by hand, it has to be something obvious.
Jim
'75 Ford Highboy 390 4spd
FORDification
Site & Forum Admin
Site & Forum Admin
Re: need some help
Post by FORDification »
...or you have your spring installed incorrectly....that is, holding the throttle open rather than closed.
