Ugg broke carburetor ear off
So unfortunately I broke the ear off my motorcraft 2bbl carb, so I have to go back to my holly which Ill have to put a rebuild kit. I guess the only way the get my money back off the motorcraft would be to find the encasing?
- 1971fordcustom
Re: Ugg broke carburetor ear off
Now How You Do That?
http://s205.photobucket.com/albums/bb31 ... d%20F-100/
1971 F-100 Explorer Special custom
1971 F-350 Flatbed
1966 Ford Galaxie!
1966 Ford F-250 4x4
1960 Ford F-750 FireTruck
1960 Gmc 6000 FireTruck
1962 IH R-185 Firetruck
1959 Ford Custom 300
1940 Ford Truck
1971 F-350 Flatbed
1966 Ford Galaxie!
1966 Ford F-250 4x4
1940 Ford Truck
What do you mean "get your money back"? encasing?
Didn't you say you broke it, we can only assume you must have WAY over tightened it, the specification is something like 7 ft-lbs which is very little.
- binder56jd
can u not buy a new base plate??? there are places that sell carb repair parts--do a little creative googling--be surprised at what is out there
ps--it's called research
now serving #235
now serving #235
if you found a new encasing you wouldn't need to get your money back.
- Redcap
I'd like to know that too.1971fordcustom wrote:Now How You Do That?
The ear broke off , well i don't think I over tightened it but what happened i think i put one bolt uneven tightness with other so when I went to tighten it, i heard a crack and didn't find out untill later. But yea, getting money back was wrong thing to say, i meant getting my money out off it. But yea the casting block unfortunately you cant weld, but whats the best way to get one? Search a junk yard and get lucky, or any sites I can go to. I had to buy a rebuild kit for old holley I have, which is better anyways. But I don't want that carb to go to waste. I would just have to transfer all pieces over.
- 1971fordcustom
Well I do have to say your the only one I know if to ever bust a ear off a carb
1971 F-350 Flatbed
1966 Ford Galaxie!
1966 Ford F-250 4x4
1940 Ford Truck
1971 F-350 Flatbed
1966 Ford Galaxie!
1966 Ford F-250 4x4
1940 Ford Truck
Yea well i don't exactly know how either, ive taken and put it on 100s of times and never had that happen, so wtf. But I just have bad luck as a person anyway.
so where is this ear that broke off? and where is the ear located at on the carb top or bototm. or is it the spacer plate that broke? i am at a loss to figure out what ear and where it is at.
The front passenger side ear, directly on the carburetor. Unfortunately, I wish it was the spacer plate, and I wish it was made outta steel so I could weld it.
Umm Jb? All I have is a modified mig and an arc welder. I use to have oxy acetyline, does it come in a pack, and you put the 2 compounds together?
- 1967AceStroker
This is JB Weld, it is some pretty tuff stuff, but not sure if it would work for that carb though.
My Project Thread (Not updated in years.)
1967 F-100, Shortbed, 351W - 72mm Single Turbo - Megasquirt MS3x Engine Management, Tremec TKO 500, Ford 9" - Strange Nodular Center Section - Strange 35 Spline Axles - Strange Full Spool - Caltracs - DJM Drop Kit, Crown Vic IFS Swapped - 2 Coils Cut, Power Steering, Power 4 Wheel Disc Brakes, Paint - Kona Blue
