Oil filter adapter gasket
mcarlson11
Post by mcarlson11 »
anybody know where I can get one for an FE without having to buy an entire engine gasket kit?
When the going gets tough, your doing something right.
ToughOldFord
re: Oil filter adapter gasket
Post by ToughOldFord »
They're easy to make, just buy a square of gasket material from a parts store, trace and cut. Don't forget the holes. :thup:
Manny
Post by Manny »
How about here most parts counter guys are idiots and can't find it but i just picked one up the other day for my engine work.
Fel pro part number 70135
http://www.partsamerica.com/ProductList ... ing+Gasket
Hope that helps :thup:
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
mcarlson11
Thanks guys. Your a big help.
FLATBEDFORD
Post by FLATBEDFORD »
That is the only part my local guy couldn't get for me so far. I did find it by chance at one of the local chain parts stores.
My Photo Gallery
thethump
Re: Oil filter adapter gasket
Post by thethump »
Question? How much oil will I be dealing with when I remove the adapter?
- David
David | Knoxville TN
My 1972 F100 Ranger XLT is For SALE
ImageImage Image
This great song mentioning a flatbed Ford was released on May 1, 1972, the band’s first single. 72 was a good year, ah yes.
Unfortunately, the ladies above are not my girlfriends.
BobbyFord
Post by BobbyFord »
Engine rebuild shop should have them laying around.
FLATBEDFORD
I took the filter off first with a pan under it. With the filter and the oil in it were dealt with, there were only a few more drops. It's higher on the engine, most of the oil will be down in the pan.
My Photo Gallery
thethump
Post by thethump »
Thanks Steve. I've not got a garage or much for tools, wanted to know if I needed a catch pan bigger than a topped of 2 gallon water jug.
ImageImage Image
FLATBEDFORD
I do all my work in the driveway too. Working on my tool collection and hoping to have a garage some day.
My Photo Gallery
thethump
Post by thethump »
I think I stopped a long time leak. The truck is new to me by a month or so, but it looks like it's previous owner fed it oil regularly instead of replacing oil filter adapter gasket. I had to cut some of the gasket away to make room between the adapter and I think was an gas filter (shocked the gas filter is not shielded from road gravel). Yes, removing the oil filter first made this tight spot workable. I used 1/2 socket, a longer extension and some patience.
Thanks
