fuel tank install
- 69rangerf100
fuel tank install
i had to replace my cab b/c of serious rust issues. got a 70 cab to replace my 69 cab i noticed that my 69 fuel tank wont bolt un since it uses the 3 bolts were as the 70 cab has the 5 bolts weld to the cab. so i have a 70 gas tank now for the 70 cab. ok here is my question. on the 70 tank there are more tubes that are coming out of of the top of the tank, can anyone shed some light on these extra lines that are on top and tell me how to do the plumbing?
David
Dream as if you'll live forever, live as if you'll die today - James Dean
Daily Driver - 1998 Honda Accord
Wife's Ride - 2007 Ford Explorer Sport Trac
Project - My Dad's 1969 F100 Ranger 390 w/ 3spd manual coming soon PS, PB, A/C and alot of paint and body work - Miss you Dad
http://s936.photobucket.com/albums/ad208/69rangerf100/
Re: fuel tank install
those extra hole are fo rthe fuel tank vent and evaportor canister. if you dont have that stuff it is ok not to use it. you can plug off those holes. but you have to use the filler neck from your 69 tank and a vented gas cap so the tank will still work properly. if you want to hook up all of those extra lines you can do it but you need the parts to do it with. i saved the last two trucks parts from the tank including the evaportor canister and all the lines if you want them.
- 69rangerf100
thanks for the offer but i just got back from Beef80's house and pickup up some of the parts that he had and got both tanks that he had and they have all the lines on top i was just wondering what they are for b/c my 69 did not have these lines.
David
thats fine if it was me i would probably block them off anyway.
- 69rangerf100
thanks for the suggestion what should i use to block them off?
David
those are a flare type of fitting. you will need a flare type of plug to put in the holes. a straight pipe plug wont seal against the fitting in the tank and you may end up smelling gas all the time if you dont use the flared pipe plugs.
- FORDification
- Site & Forum Admin
If you block off those charcoal canister lines, your tank will no longer be vented. You'll then need to use the '69 filler neck and vented gas cap. The vented cap won't fit on the '70-'72 filler neck.
- 69rangerf100
ok i know that this is going to sound like a stupid question, but the filler neck is the metal tube that sticks out of the cab am i correct?
David
- FORDification
Yes.
