float issue? fuel pressure issue?
- mad2smile
alright, so i made a few carburetor adjustments, as instructed in my other thread (http://www.fordification.com/forum/view ... =3&t=39580). trouble is, there is still fuel coming from the bowl vents. after starting the truck, it takes about 1-3 seconds for the fuel to start pouring over the vents. i know this is probably a float issue, but when i remove the top of the carburetor, the float is floating (not sunken), and the stopper on the other side is fully seated.
i really need to get rolling again. any help would be greatly appreciated.
1976 Ford F-150 Supercab 4x2 w/390FE engine C6 - 76,000 miles
1995 Taurus SHO 3.0L Yamaha V6 MTX w/Quaife LSD - 75,000 miles
2002 Dodge Neon R/T 2.0L I4 MTX - 91,000 miles
1993 Dodge Ram 3500 5.9L Cummins 6x4 Flatbed MTX- 100,000 miles *SOLD*
Re: float issue? fuel pressure issue?
do you think the float might be sticking open?
- BobbyFord
Did you buy a O/H kit or just go in to make adjustments?
I would buy a kit with a new needle valve and seat and adjust the float using the cardboard gauge in the kit...
- 19674x4
another thing is do you have the stock mechanical fuel pump or an aftermarket electrical one.....
My Photo Album
- mad2smile
mechanical pump. replaced about a year and a half ago. swapped from old engine to 390.
the carburetor was rebuilt with an overhaul kit, including a new needle and seat.
- BobbyFord
Then the float is not properly adjusted or there is a piece of dirt between the valve & seat.mad2smile wrote:mechanical pump. replaced about a year and a half ago. swapped from old engine to 390.
- mad2smile
no dirt. i made sure. and ive checked the float and fiddled with the adjustment many times and the issue keeps happening.
it almost seems like the fuel pressure is too high, but its the same pump i used before. i thought about getting an inline regulator, but it still doesnt make since because the pump worked fine before.
- mad2smile
i left the float adjustment the same as it was when the carb was on the other engine. it worked just fine then, but was overflowing on this engine after the carburetor was rebuilt. as stated earlier, i have fiddled with the float a few times since then, but same issue.
- BobbyFord
Who O/H'd the carb? If it was you, how many have you done? (Sorry, not trying to sound like a jerk).
- mad2smile
no offense taken.
i did the rebuild, and it was my first time doing so. i took my time, and made sure all parts were accounted for.
- BobbyFord
Hmm...sounds like you just gotta keep fiddling with it. Maybe just something simple that you cant' see because you in too deep...
- mad2smile
it probably wouldnt effect anything, but i just remembered that i didnt put the small screen in under the seat. the rebuild kit didnt come with one, so i left it out. the old screen is in good shape, so im gonna try to see if installing it makes a difference at all. probably not, but who knows...
the screen helps keep the dirt out of the fuel bowl. is your float catching at all whent he fuel bowl is full? can you push down on the float and it springs right back up everytime? or does it catch on one push or another? if it catches something is stopping it from working properly and that is the flooding problem.
- mad2smile
float moves freely.
- mad2smile
tried adjusting the float further down. no difference. here are a couple of pictures of the float level. at this level, the needle seems to be fully seated, but fuel is still getting by somehow.
