MLJJONES67 PROJECT CUMMINS put away for winter
averagef250
Re: mljjones67 PROJECT CUMMINS UPDATE
Post by averagef250 »
That's the small block adapter and a saginaw pump.
mljjones67
Post by mljjones67 »
Ok thanks Dustin. I will try for the pump.
M-100
Post by M-100 »
That looks like a cool project. I was looking at the pics of the cab on the engine lift . Just wondering how you hooked the lift to the cab?
mljjones67
I hooked chains up to bolts that I put in existing holes. The front holes are capped off with a grommet plug. I used big washers in those spots and long bolts through the cab mount location in the rear.
On a side note I bought this gauge cluster off ebay today.
http://cgi.ebay.com/ebaymotors/ws/eBayI ... &viewitem=
and I want to install this tach in place of the vacuum gauge.
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 0160302204
The seller says its 4" around. What size is the vacuum gauge hole? And how can it I get the tach to work at with my cummins? It looks to be a mechanical tach.
M-100
Post by M-100 »
Thanks that is a good idea.
mljjones67
1971ford
Post by 1971ford »
mljjones, the links dont work because they were shortened and the other half is no longer a link and some of it is missing. if you cant get it to link then how about copying a picture or two from the ebay listing.
mljjones67
Sorry the links are the same as the ones above it. I just bumped it.
We are talking about it here also.
http://www.fordification.com/forum/view ... =6&t=38501
mljjones67
Another pump on ebay Right one???
mljjones67
Motor mounts
I am wondering if these are the right motor mounts.
Part#2469 Anchor
http://www.rockauto.com/catalog/raframecatalog.php
averagef250
The rockauto link doesn't work.
Use whatever mounts you want. If you run the gen1 dodge blockside mounts then gen1 dodge biscuits match up to them and you can build frame stands to match. The dodge biscuits aren't the best though. Stock engine they'll work fine, bigger power and they go sooner than they should.
I've been thinking about trying to piece together highboy frame stands for a 6BT using the 90's ford powerstroke mounts. They're pretty rugged and actually have a design that keeps the engine in plkace if the rubber brakes.
mljjones67
Rock auto wont let me directly link to a part so you just have to put in the part number and brand name. I got the part number off of 4btswaps it is for the 4bt for block mounts I believe, I still need to find those if I use that setup. If it will even work.
Dustin,
Can you give me the dimensions to cut down my 79' engine stands. Soon as I get my welder and practice a little I will cut them down. Oh on the 79 the engine stands are different heights, will that make it different to cut down the 2.5" I will throw some pics up when I get back to Utah.
Thanks again Dustin
averagef250
You can use your frame stands for a 4BT install. With the six you have to make entirely new engine mounts. The six does not mount the same.
The 4 uses front mounts. The six has mid mounts.
mljjones67
I found another Saginaw pump I think?
Is it the right one?
mljjones67
Dustin, Is this the saginaw pump I need? He wants $50.00 plus shipping
