360 into a 390
jay1213
360 into a 390
Post by jay1213 »
I know what is needed 2 do this swap, a 390 crank. My question is I've looked up reman 390 cranks at work(bc all the local yards have no fe motors) I have different casting numbers on the cranks I'm looking up, what number should I use????
Re: 360 into a 390
i woudl guess that it depends on wheather you want to build it to car specs or truck specs.
jay1213
Re: 360 into a 390
Post by jay1213 »
I would imagine I would want it built to truck specs? I'm just looking 4 that extra oopmh, and I get the crank 4 about 100 bucks, and the engine work is done by me so....
Re: 360 into a 390
thisis for a 71 with a 390 or 6.4 L. this is a crankshaft kit. it shows several part numbers under the part. http://www.autozone.com/N,15100229/shop ... ultSet.htm i use autozone for quick parts look ups. thats why the link is what it is. because it is quick. that didnt work sorry. if you look it up it will show you the part numbers under the picutre for the crank.
jay1213
Re: 360 into a 390
Post by jay1213 »
The connecting rods are the same correct???
Re: 360 into a 390
no they are shorter i think for a 390.
jay1213
Re: 360 into a 390
Post by jay1213 »
All my research indicates that they are the same pistons and rods, the only difference is crank, if anybody could shed some definative light on the subject would b appreciated
FORDification
Site & Forum Admin
Site & Forum Admin
Re: 360 into a 390
Post by FORDification »
The overall length of the piston/rod on a 360 is longer than on a 390...the 360 pistons would stick out of the block if you just swapped in the 390 crankshaft. You can use the 360 pistons OR the 360 rods in a 390, but not both. (That's how 360's were built...using the 390 piston. The compression height of the 390 4V pistons with the long 352 rods and 3.50 stroke crank made 8.2:1, 390's used the 410 4V pistons to bring it down to 8.4:1.) The compression height of the 360 pistons is 1.776", which makes the perfect 390 piston. The 360 long rod is .052" longer than the 390 short rod, which combined with 1.680" compression height 390 truck pistons would also give good compression. However, the 360 rods are somewhat weaker than the 390 rods.
Incidentally, factory 360 pistons have '390 4V' cast into them.
jay1213
Re: 360 into a 390
Post by jay1213 »
So to sum it up, 390 crank and connecting rods is all that's needed??
sideoilerfe
Re: 360 into a 390
Post by sideoilerfe »
and pistons. the compression height is different and the stock 360 pistons have a full skirt as the 390 pistons do not.
1970 F250 4x4 390/4spd
1968 F250 4X2 360/C6/No Rust!
jay1213
Re: 360 into a 390
Post by jay1213 »
I know the height is different, but it should be fine correct???
Re: 360 into a 390
It should be fine with a 390 crank, rods and pistons. :wink:
If your 360 has the full skirt pistons, I think you will find that they hit the crank. If they are marked 390 as outlined by Keith you can use them. However they are not horrobly expensive so in this case "can" does not neccecarily equal "should".
sideoilerfe
Re: 360 into a 390
They would hit the 390 crank but they're stock in a 360.
Re: 360 into a 390
Thanks for clarifying, that is what I meant they will hit the 390 crank.
sideoilerfe
Re: 360 into a 390
I knew what you meant but I just wanted to clarify for Jay1213.
