HRDROKN
Re: 1969 Ford Crew Cab / Cummins Project
Post by HRDROKN »
Nothing like a new motor to get things rolling.... :woohoo:
I found this one on Craigslist for a reasonable price! The short block is ready to go, all built with Cummins West bearings and gaskets. ARP head studs, nice HX35, built P7100 and all misc pieces. Just need to get a head.... o-ringed and ported.
So I will be getting back to this project after the holidays!
:thup:
rjewkes
Post by rjewkes »
cool now is that or i guess all bt4's and 6's pump driven fuel delivery or are some suction/syphon driven? our big cummins in the F650's are 4 cylinders and syphon driven fuel delivery.
fuelly.com
RedneckTexan
Post by RedneckTexan »
That's a SWEET find Mark! :thup: :thup:
John
68 F-100~68 F-350~69 F-250~69 F-100
76 F-150~78 bronco~78 bronco
http://oldfordcrewcabs.com/
HRDROKN
Post by HRDROKN »
averagef250 wrote: That block looks like it was decked, make sure you know exactly how much so you can run the right thickness head gasket.
Very good point! Yes the block was decked and I wasn't even thinking about the propper deck height.... do you have a spec for it?
Thanks!
:thup:
HRDROKN
Post by HRDROKN »
Anyone know off hand, how much the Cummins short block weighs?
averagef250
Post by averagef250 »
With the shortblock assembled you should be able to measure exactly how far the pistons are sitting above the deck and determine how much was decked. Piston quench is critical on these. A few thou off and you can raise compression cosiderably, better to be too low than too high on an engine you're going to run hard.
Not exactly sure, but I'd guess about 750 for the shortblock. My engine stand's built from 1" T-1 plate and 1/2" wall 4" steel tubing and it groans quite a bit with one on it.
HRDROKN
Post by HRDROKN »
More parts parts parts parts coming in.....
O-ringed cylinder head...
Airdog 150....
1.375" input shaft....
:hd:
HRDROKN
Post by HRDROKN »
Five packages at the door today! The wife was kinda complaining that she couldn't hardly get through the door!
:thup:
mljjones67
Post by mljjones67 »
nice!!!! Thats all I have to say!! :thup:
HRDROKN
Post by HRDROKN »
Purchased this 5" exhaust from a company that enables you to get just the pieces that you need... since I dont need a downpipe, it worked out great! I added an extra piece of 5" straight incase I needed to add some length...
My boy is thinking it's all wrong though!
Hey Dad this stuff is too small... even I can't crawl through it!
:thup:
BiggDogg
Post by BiggDogg »
Man this project is awesome. I love those seats :D Thanks for the updates keep 'em comin' :thup:
1970 F250 Camper Special
averagef250
Pretty head, but it looks to have a few too many pounds of iron in the ports (needs some grinder action in there). Lookin good!
HRDROKN
Post by HRDROKN »
averagef250 wrote:Pretty head, but it looks to have a few too many pounds of iron in the ports (needs some grinder action in there). Lookin good!
Yes.... at this point I'm thinking that some clean up in the bowls and port matching is in order, unless I find someone local has some skills!
:wink:
HRDROKN
Post by HRDROKN »
Since this baby has a real home now.... I have decided to go ahead and run coilovers up front on a four link set-up. At first I was going to do this as kind of a side bar to getting the truck on the road this summer. Now I'm seeing some advantages to upping the priority on this.... So just about all the parts have been ordered to make this happen! Even purchased a decent manual tube bender and a couple dies.
At least with the coils I should get a pretty decent ride! I'll look at doing the rear down the road...
8)
averagef250
http://www.zzcustomfabrication.com/head_porting_08.html
Some good pictures here of what the ports should look like. If you have the bucks these guys do some pretty nice work, runs about $4K for a worked head with a standard entry intake. There is a lot to gain in port work. The bowls are pretty bad in stock form.
