Truck jerking
- wildcard
Truck jerking
Just put in new points, cond, plugs, wires and reset timing. Problem is when I let off the throttle coming up on a stop sign or such, the truck goes to jerking like it's bogged down. I know that's not the reason though. Out on the road it seems to run smooth and steady. Double checked gaps in points and plugs. Still good. Tried slight adjustments on timing and nothing seems to help. Any ideas ?
- Dragon
Re: Truck jerking
Carb going overrich on slowdown. Float level too high.
Old Fords Rule
Was a Ford Service Tech
98 Volvo S70 2.4T Auto
My Gallery
Spark test
My Gallery
Spark test
- wildcard
Re: Truck jerking
So, it's a single barrel carb and I know absolutely nothing about them except how to install. Got any instructions I could probably screw up ? Any pics would extremely helpful also. Thanks. I've been just putting it in neutral and rolling to keep it from jerking.
- Dragon
Re: Truck jerking
Enjoy
Old Fords Rule
My Gallery
Spark test
My Gallery
Spark test
- wildcard
Re: Truck jerking
Thanks Dragon, that helped a bit.
