fuel filter???
fuel filter???
Has anyone EVER seen a filter like this? It has a FORD number on it. Kinda COOL. Think I'll add it to my FORD tool collection.
-Lance
-Lance
Re: fuel filter???
I removed it from a '62 comet.
Re: fuel filter???
That's weird my 60 Comet dosen't have one. What size motor?LANCE65 wrote:I removed it from a '62 comet.
60 Mercury Comet
65 Ford Econoline
77 Ford F250 "lowboy" 4x4
09 Harley Xl1200c
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
Re: fuel filter???
it had a 289.
-Lance
-Lance
- willowbilly3
Re: fuel filter???
Yup, my 62 Sunliner had one, I pitched it.
Also Chevy trucks had those in the 70s, maybe later. Theirs mounted on the rh framerail behind the front tire and too the same can and filter as a Ford, but didn't have Ford script obviously.
Re: fuel filter???
Ohh ming has the orignal 144 small but I like it being all orignal Someday I want to put a 302 in one.LANCE65 wrote:it had a 289.
-Lance
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
Re: fuel filter???
I was over on the FE forum and someone posted a filter like this that sold for 200 and change! They say its for a tri-power set up!?? Any truth to that? I have created an account over there,but can not post anything yet?
Thanks,
-Lance
Thanks,
-Lance
Re: fuel filter???
if they say its worth that clean that one up and post it for sale for 250.00 and see if you get any offers over there.
- reflectionpoint
Re: fuel filter???
This looks kind of like the filter mounted to my mechanical fuel pump, only mine is smaller diameter, I think. If it's worth that much I'll sell mine too.. I have a clear one that I put inline after my tank selector that's doing all the work anyways.. but I think mine is more 'standard equipment' and nothing special, I'll have to take a closer look.
-~Eric
-~Eric
Life's a beach.. then you get swimming lessons.
--'72 F102 LWB, RWD, 390 FE, C6, 3.50 Open 9", Current Project.
--'63 F350 LWB, RWD, 390 FE, T18, 5.13 Open D70, future car-hauler.
--'94 Explorer Limited, 4x4, 4.0 Cologne, Auto, 3.73 LS 8.8", Kid Hauler
--'93 Dodge LWB, 4x4, 12v Cummins, Manual, 4.10 Open D60/D70, Newest member.
Re: fuel filter???
the filter on the bottom of your pump isn't the same as that one. because that one mounts to the frame of a car. the ones on our trucks screw to the bottom of the fuel pump and that is bolted to the enigne.
- reflectionpoint
Re: fuel filter???
That's kind of what I thought, and why I figured I'd shut up before I dug myself too deep in the 'dummy' hole.fordman wrote:the filter on the bottom of your pump isn't the same as that one. because that one mounts to the frame of a car. the ones on our trucks screw to the bottom of the fuel pump and that is bolted to the enigne.
Thank you for the clarification.
-~Eric
Re: fuel filter???
That is the same filter on my 67 F100 with the 352 motor. You unscrew it and the filter is inside. I know because the gasket on mine is starting to leak so time to replace the filter anyway.
FTM.
FTM.
1967 F100 LWB
1972 F100 SWB 4x4
Assorted Harleys
1972 F100 SWB 4x4
Assorted Harleys
Re: fuel filter???
yes same filter and same filter can but different filter holder.
