2bbl vs 4bbl vs 3904bbl swap
Re: 2bbl vs 4bbl vs 390 4bbl swap
Let us try to stick to the topic, if I read the original posters proposition correctly, he has both the 352 and the 390, since he does not have a 429, 460, 514, 888, 1025, or 300 six those suggestions are not really helping him with the decision...
- 19674x4
Re: 2bbl vs 4bbl vs 3904bbl swap
i kinda wanna pull the pan on the 352 to check the bearings to see if i should go ahead with the intake and carb but part of me wants to throw the 390 in there.
My Photo Album
- SteveC
im planning on adding a factory four barrel intake to my 352 after rebuild
1967 f-100 4x4
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
1967 f-100 4x4
- willowbilly3
Some headers fit and some don't. Which manufacturer did you use that advertises theirs to fit a 65? That would be good information that we didn't have before.sideoilerfe wrote:Not true. I had a 65 with a 352 and installed headers with the stock towers. No modifications required.willowbilly3 wrote:... You may have to find a 69-later left side engine stand. The earlier ones are different and most header manufacturers don't list their headers to fit the 352 equipped trucks because of that.
I run a 390 and it's ok but I would sure never pull a healthy 352 to put in a 390. Have you tried a different 2 bbl? Maybe the race car carb isn't as efficient as it could be. I run a 350 Holley on my 390 and get around 12 mpg on the highway. City mpg I don't even want to know.
And fwiw, there is an easier way to deal with those broken off bolts without removing heads or engine. Keith has a picture up somewhere of an engine with the 5/16 bolts all the way through with nuts on the back. To get out the broken ones, I use a cutting torch but you need to be pretty handy with one to try it. A compact angle head drill and a short bit will do the trick too.
- Kurt Combs
I am running a bone stock 360 with a two barrel in a 1972 F-250, C-6, power steering and brakes, and it gets a legitimate 13-14 miles to the gallow on the highway. Mileage was checked using Mapquest for the distance and topping off the gas tank before and after the trips. I do drive between 65 and 70 and the engine is old and a little tired, but it keeps on going. BTW, I almost never "floor it". There was some mention of duals above, sound nice, but that is about all I ever noticed for performance/mileage between single and duals. Just my
Kurt
1972 F-250
1972 F-250
- willowbilly3
So I asked for info on your headers, where is it??? If you are going to call someone a liar you could at least substantiate it with some facts.sideoilerfe wrote:Not true. I had a 65 with a 352 and installed headers with the stock towers. No modifications required.willowbilly3 wrote:... You may have to find a 69-later left side engine stand. The earlier ones are different and most header manufacturers don't list their headers to fit the 352 equipped trucks because of that.
Let us not get personal...
If a discussion needs to be had, please do it via PM's or E-Mail not on the open forum.
Thank You.
Thank You.
