how would you remove this nut?
1971ford
Post by 1971ford »
it is now stripped, and it is so tight on there its like its welded. havent gotten it to budge at all. you can see that i have gotten a very tight lock on it with vice-grips by the indentations on the nut. but still, it didnt budge. instead it just repeatedly sends me knuckles into the bellhousing.
ive tried removing that exhaust pipe, but the nuts of the exhaust pipe connecter are giving me the same problems.
its the only thing holding the engine in.
its not a very nice nut at all :hs:
binder56jd
re: how would you remove this nut?
Post by binder56jd »
air chisel or cutting torch--all 3 of em
now serving #235
marine6212
Post by marine6212 »
1971 Ford,
Can you fit a nut splitter in there? Or you could go to Harbour freight and get one of the Torch Pens for a couple of bucks and it will give you a flame like a torch for about 30 seconds to a minute to heat it up and break it loose. just my thoughts and :2cents:
Semperfi,
Marine6212
We all came together, both young and old.
To fight for our freedom, to stand and be bold.
In the midst of all evil, we stand our ground.
And we protect our country from all terror around. Peace and not war, is what some people say. But I'll give my life, so you can live the American way. I give you the right to talk of your peace. To stand in your groups, and protest in our streets. But still I fight on, I don't bitch, I don't whine.
1971ford
Post by 1971ford »
air chissel is a possibility, but i dont think it would do anything. at least mine wouldnt since its a HF pos.
dad says a nut splitter probably wouldnt fit, but ill have to check. never heard of a torch pen, they sound fun :D sounds like its worth a shot
thanks!
convincor
Post by convincor »
cut both sides of the nut off with a die grinder/cut-off wheel(without hitting the stud). Then hit the right side of the flat you made with a chisel. Should split right off. The nuts only aluminum...
"Still Plays With Trucks"
1971ford
Re: re: how would you remove this nut?
Post by 1971ford »
convincor wrote:cut both sides of the nut off with a die grinder/cut-off wheel(without hitting the stud). Then hit the right side of the flat you made with a chisel. Should split right off.
sounds good, a cut off wheel wouldnt light the grease on fire or anything? that could get exciting really quick
convincor
Post by convincor »
that's why I don't play with fire wrenchs :wink:
I know a guy that lost a couple cars as well as a customers car playing with fire. :doh:
CO684X4
Post by CO684X4 »
These work great. I use them all the time at work. Just tap them on with a hammer and then use a socket and remove the nut.
http://www.sears.com/shc/s/p_10153_1260 ... s+%26+Dies
rubiranch
Post by rubiranch »
I think I would start another nut on that stud and braze the two nuts together.
Once they are brazed I would heat the "bad" nut and try to loosen it by putting your six-sided socket on the new nut.
I hope there's enough room.
:fr:
fomocoguy
Post by fomocoguy »
Just keep a fire extinguisher handy! :lol: Seriously if you can't get to it just see if you can borrow an oxy-acetylene torch set from work (if they have them) and get that nut cherry red, then use the vise grips. It'll come off. I have a small portable set for soldering a/c lines on my work van that I've used a number of times on my jeep. Just watch for things you could catch on fire, it's approximately a 6000 degree flame :thup:
ON SECOND THOUGHT, there is a torque converter full of oil on the other side of that nut. Maybe the nut splitter would be a better idea...
ALTHOUGH, the flywheel will make a pretty good heat shield. Decisions decisions... :D
Joe
1971 F100 flareside 8ft
2006 Dodge Ram 2500 cummins
2005 Ford Ranger
FORDification
Site & Forum Admin
Site & Forum Admin
Post by FORDification »
Hmmm....I recently had to deal with this exact same scenario:
I basically just did what convincor suggested, except that after I removed both sides of the nut with the cut-off wheel, I just grabbed the remainder with a pair of ViceGrips and it twisted right off.
marine6212
This is what my pencil torch looks like!!Image
[/img]
1971ford
Post by 1971ford »
:eek: thats even the same exact nut. what a coincidence :D
ill try that tomorrow :)
1971ford
Post by 1971ford »
marine6212 wrote:This is what my pencil torch looks like!!
that is 8) 8)
mljjones67
Post by mljjones67 »
Can you pull the engine and trans out together?
