1971ford
Post by 1971ford »
thanks and also we just looked at the rebuild kit... no instructions what-so-ever :roll:
truckguy
Post by truckguy »
1971ford wrote:thanks and also we just looked at the rebuild kit... no instructions what-so-ever :roll:
Good luck with that. :lol:
Kyle
Image ImageImage
1986 F-150 300
1972 f-250 360 PS,PB
1970 F-350 360 PB
1969 f-250 390 CS,ranger, PS,PDB,AC
1968 F-350 360 PB
1968 f-250 360 PB
http://s222.photobucket.com/albums/dd207/truckguy_02/
67 ford f100s rule
re: 1971 f250 DESERT truck- rattlecan rebuild
Post by 67 ford f100s rule »
yep looks like your on your way to havin it ready for the road.err i mean sand. :wink:
Jeff Penland
70 Ford F100 LWB "Nadine" 302/3 speed with overdrive
If you have to ask you wouldn't understand
"I shall hold the line of right as well as that of glory." English translation of the British Penland coat of arms.
RedneckTexan
Post by RedneckTexan »
Lookin good Ryan! :thup: :thup:
John
68 F-100~68 F-350~69 F-250~69 F-100
76 F-150~78 bronco~78 bronco
http://oldfordcrewcabs.com/
seattle67
Post by seattle67 »
And yes, it's a scientifically proven fact that shiny does indeed equal faster! 8)
Dan
"I plan to start procastinating immediately"
FordTruck
Post by FordTruck »
Looks good!
Are you gonna run the stock exhaust manifolds?
60 Mercury Comet
65 Ford Econoline
77 Ford F250 "lowboy" 4x4
09 Harley Xl1200c
1971ford
Re: re: 1971 f250 DESERT truck- rattlecan rebuild
Post by 1971ford »
thanks :D
FordTruck wrote:Looks good!
for now what we are going to hopefully do is bend the existing pipes enough to fit the 429's manifolds. then we will run it like that for quite a few months then swap in headers and new exhaust :thup:
rjewkes
Post by rjewkes »
Clean and smooth shure keeps drag down :thup:
fuelly.com
RedneckTexan
rjewkes wrote:Clean and smooth shure keeps drag down :thup:
purty does to! :thup:
John
1971ford
Post by 1971ford »
update, but sadly it doesnt include pulling the 360 or swapping in the 429 :(
it wont be going anywhere for a while.
-dad and i rebuilt the tranny with our TCI rebuild kit and the new manual/auto valve body
-took the motor mounts to the welding shop i work at and had a big gusset tacked on. still needs to be welded up obviously
there is ONE nut keeping the 360/tranny in the 71. and OF COURSE, its the last one that had to be removed. and of course, its stripped, and of course it is pretty much welded on. its one of the nuts that are on the flywheel. and of course you cant get at it with a nut buster or grinder or anything, you can only get at it with vise-grips which leads to a very long time under the truck bashing your knuckles on the tranny housing :x :hw:
i dont think we will have any problems with strenght of these now
beautiful weld on the "ears" of the tranny
ohhh man look at all these parts that have to go back in exactly as they were removed.
back together
8)
hope to have the 71 driving within 3 weeks (just a random time that i would like to be done by) so we can take it to the short-course offraod track by our house for a little testing of the new motor 8)
TheEskimo
Post by TheEskimo »
Nice work as usual, how bad was it to rebuild one of those anyhow?
-Jason
1972 F250 Camper Special 360ci
1973 F100 Custom 390ci
1985 Thinderbird 302ci (DD)
kaptnkaos
re: 1971 f250 DESERT truck- tranny rebuild, motor mounts
Post by kaptnkaos »
Dang Ryan...
How many extra parts did ya end up with???
I know if I did one, there'd be at least half a dozen parts left over... :D
When I did the stuff on my '68 CS this winter, I know I put every bolt back in, but still ended up with a coffee can full of extra bolts...
wwwuuuuzzzzuuuupppwwwiiitttdddaaattt??? :dk:
KaptnKA 8) S
1971ford
Post by 1971ford »
thanks,
we bought a book from Borders that covers how to rebuild auto tranny's from ford. so we followed it closely. my dad had to do all the thinking but it was pretty hard putting it back together without screwing up. and it takes a long time, we thought it would be done in a few hours, but it took us like 6 or so, since we kept taking the end back apart to make sure we had it right. there are some things that make you think "whaaaaaaaaaaatttt????" and then you figure out that say the piston isnt fully seated and then it all works and fits.
id hate to rebuild a tranny again but will if i need to (with my dads help :D )
kaptn,
luckily, no extra parts lol
there would accasionaly be a extra thrust washer or something on the bench and i would have to ask my dad where it should of gone, usually it was just the last thing we put in that needed it.
man if we had to tear apart the whole thing after finding a left over part, i would go crazy
oh and there was a screw in the pan when i pulled it. one of the valve body screws. interesting
ZOEGA
Post by ZOEGA »
unclejtl
Post by unclejtl »
that's a cool truck!
Jason
