HRDROKN
re: 1969 Ford Crew Cab / Cummins Project
Post by HRDROKN »
Hey MadMaxetc....
Great job on that illustration! Would you mind if I used you post in a couple other forums?
Mark
HRDROKN
Post by HRDROKN »
Dana 80 getting disc brakes......
:D
rjewkes
Post by rjewkes »
cool, question on front alignment as far as centering the axles, is the little shackle mount with the hole in it designed to center exactly on the the little nob deal on the springs or is there room for error?
i ask as here in a month or so i'll be changing the worn out u bolts and just want to get it right.
is there a trick to getting it centered? does this apply to both axles on a 4x4?
fuelly.com
HRDROKN
Post by HRDROKN »
rjewkes wrote:cool, question on front alignment as far as centering the axles, is the little shackle mount with the hole in it designed to center exactly on the the little nob deal on the springs or is there room for error?
The locating pin (spring pack bolt) fits the hole in the top of the spring perch on the axle. Not really any room for adjustment, it generally is what it is.
:wink:
rjewkes
Post by rjewkes »
sweet justy get it in there and tighten awesome.
fuelly.com
MadMaxetc
Re: re: 1969 Ford Crew Cab / Cummins Project
Post by MadMaxetc »
HRDROKN wrote:Hey MadMaxetc....
Mark
Go for it.
Dan
Project: '63 F-100 LWB / 460 / C6 / 2x4 / Work In Progress!
Daily Driver: '67 F-250 Converted to F-100 LWB / 300 / T-5 / 9" 3.70:1 / 235/75R15 Tires
1/4 mile in 17.64s @ 75mph (it's 4200lbs!!!)
"Work Harder! Millions On Welfare Depend On YOU!!"
FORD Girl
Photobucket Pictures
HRDROKN
Post by HRDROKN »
Mark
Go for it.
Thanks!
:thup:
HRDROKN
Post by HRDROKN »
This last week I worked on the power steering mount. Thought about many different ways to skin this cat, but decided that I didn't want bolts sticking through the frame.... so here's the pics. Somehow I had taken more pics during fabrication of all this, but they didn't write to my card... Hmmmmm.
:wink:
HRDROKN
Post by HRDROKN »
Needing a little insight....
Looking on line for brake rotors and it seems that I can find rotors for the 1979 model year, but very little comes up for the 1978 model year So whats the difference and how would I determine exactly what year axle I have? Or does it matter?
Also I noticed that the calipers on the D60 appear to be the same as that D44 HD that I took off the truck.... Hmmmmm.
averagef250
Post by averagef250 »
They are exactly the same.
HRDROKN
Post by HRDROKN »
Finally feel like I'm getting somewhere this week.....
Still waiting on all the rebuild parts for the axle... new kingpins, spindles, bearings, u-joints and seals.
:D
rjewkes
Post by rjewkes »
lookin good.
fuelly.com
67mann
Post by 67mann »
:yt: The welding looks great :thup: nice progress
HRDROKN
Post by HRDROKN »
I just sold my old axles as a pair, so time to get that old D60 out of the truck and prepair the D80 to go under. I will be changing the rear springs to 3" wide later down the road....
Out with the Dana 60....
And in with Dana 80..... almost.
8)
RedneckTexan
Post by RedneckTexan »
That D80 is a BEAST!!!! :rock:
John
68 F-100~68 F-350~69 F-250~69 F-100
76 F-150~78 bronco~78 bronco
http://oldfordcrewcabs.com/
