Best Air compressor for body work around $500.00
69twotone
Post by 69twotone »
Hi all,
I have about 500.00 to spend on a air compressor. I am wondering if I can get one that will run any tool I need to complete the body work on my truck. I need to be able to run a dual action sander, and paint gun. as well as anything else needed to complete the job such as a sandblaster. I would prefer not to add the cost of wiring a 220.
What do you guys reccomend?
69 f100 Custom cab Two tone maroon and white
Looking for a steering wheel with the horn ring, maroon or any color. PM me
67mann
re: Best Air compressor for body work around $500.00
Post by 67mann »
I have a Campfield/Hauss 26 gal/5hp---does most everything I want to do
and is run off a 20amp breaker. That was from Wallyworld(with some air tools)for 270$. I would have to say Lowes,Sears,Home Depot,etc will have a decent one in your price range.You might want to consider getting one that will convert to 220(runs more efficant)in the future :2cents:
FoMoCo
Post by FoMoCo »
I bought a new I/R 60 gallon twin piston for 440, but knew the right people. Look for a used unit, they are a better value than new if your only using it hear and there. I would not recomend a direct drive unit, rather get one that requires a belt. Spend some money on a good dryer unit around 100. The standard body shop unit is called a "toilet paper" filter because the filter resembles a roll on tp.
Nick
1969 F-100
2006 Fusion SEL
2006 e-320 cdi
2004 excursion V-10
H-DFord
Post by H-DFord »
My brother in law found a nice one at Harber Freight for around $400. And it's a 110 but I do agree if you can add 220 line it would save you electric $'s.
1968 Ford Ranger Lb
2007 Harley Electra Glide Classic
69twotone
Post by 69twotone »
Thanks guys, sounds like I may have to go to the 220 route.
skiziks
Post by skiziks »
If you can do it 220 is the way to go.
I love my Speedaire compressor and if you know someone who works for Grainger you can get one for a great price.
Larry
'68 F250 Ranger Camper Special 390 - C6 2 wheel drive - my Grandfather bought this truck with 4 miles on it!
'SOLD - :( -69 F100 Flare Side short bed - was a 6cly 3 speed - now is a 302 3 speed - will be a Fuel Injected 5.0 with a 6 speed
67mann
Post by 67mann »
:eek: Scrap the 26Gal.--1day of sandblastin :doh: and done--she did me good for 4yrs,but never ran her to that Xtreme. So 69--TSC has a 60gal.3.5hp 240 volt--campfeildhauss for 400.$--I'll let ya know how it does :thup:
72stepside
Post by 72stepside »
My father has this one...
http://www.homedepot.com/webapp/wcs/sto ... 401+524403
It has never missed a lick with blasting or painting.
Chris
Hedman Headers
Disc Brakes
Comfy Crown Vic Seats
71 F250 PS, PB, AC, Auto, 390
69twotone
Post by 69twotone »
Thanks 72 stepside that compressor is top on my list now I just need to find someone to run a 220 for me. I called one guy today and he wanted 500.0
Thanks 67mann let me know how it runs for you.
67mann
Post by 67mann »
:eek: 500$ --I don't know your set up,but does something magor have to be done to accomplish this?My new motor is 240volt/15amp which = DBL
20amp breaker and using 12/2 wire with the Neutral as hot along with the black.I thank my lucky stars for the cicle of friends(trade oriented)I have and take for granite alot of what comes with that. :oops:
69twotone
Post by 69twotone »
It would have to travel a long distance. I live in a tri-level home and the breaker is in the basement. So it would either have to travel about 80 feet on the outside of the house. Or it would have to travel through the basement ceiling up a wall in the family room through the ceiling and back down a wall.
I agree though I would not figure this to be a big job, I am certainly going to get a couple bids, and see if a friend knows a friend who knows how to do this.
On a side note the electrician told me you can not run a 220 off of another 220. Is this true? There is a dryer 220 in the laundry room about 10 feet from the garage.
I have given thought to hijacking my wifes dryer outlet, but that may cause some fights because of the noise (laundry room is right behind the family room where the main tv is.
67mann
Post by 67mann »
You would have to take turns on the use of the outlet--and I don't think thats a "give&take" situation you want :lol: :P . There wouldn't be enough amps to share a 220.
